cisco nexus upgrade
cisco8887
Level 2
Level 2
Hi guys,
can one upgrade the nx-os with old kickstart and new system image ?
for instance kickstart 7.0.1 with system of 7.1.4?
also when I did compatibility check on the new image this is what I saw. I am confused as the hardware supports 7.1.4 but below it does say incompatible image !!
Compatibility check is done:
Module  bootable          Impact  Install-type  Reason
     1        no             n/a           n/a  Incompatible image
     2        no      disruptive           n/a  Incompatible image
   100       yes      disruptive           n/a  Incompatible image
   102       yes      disruptive           n/a  Incompatible image
Manoj Papisetty
Kindly paste the complete output of the install all command. Incompatible image could refer to the fact that the upgrade will be disruptive and not ISSU. This is possible if you do not pick a correct upgrade path as per the guide.
Manoj
