cisco Nexus5548 is not accessible via management and console
karinn001
We have a  cisco Nexus5548 Chassis ("O2 32X10GE/Modular Universal Platform Supervisor"), its not accessible through SSH and console. Kindly help us, currently we have isolate the switch from the network and redundant routing the traffic.
Mark Malone
can you post the config you have setup for the  mgmt. port , is the default route set in the vrf with the context set as well for the mgmt. vrf
can you ping the device ok , have you created ssh keys ? turn the feature on as well
conf t --- feature ssh
setup for mgmt. port
vrf context management
  ip route 0.0.0.0/0 x.x.x.x
interface mgmt0
  description xxxxxxxxxx
  vrf member management
  ip address x.x.x.x
console out of the box is not blocked at all what prompt do you get when your connected to console port
Mark Malone
interface mgmt0
  ip address x.x.x.x
