06-07-2024 12:27 AM - edited 06-07-2024 12:27 AM
Dear Support Team
We bought two new Nexus C93180YC-FX3 device and after OS upgrade fans still running 70% however the server room temp is 18. How can I adjust the fans?
Br
Gábor
06-07-2024 03:37 AM
- FYI : https://bst.cloudapps.cisco.com/bugsearch/bug/CSCwd55044
Also check output from : show environment fan detail
M.
06-21-2024 05:03 AM
I want to set this manually, because 30% is more than enough, you don't need to go to 70%. After issuing the command, I can only see that it is running at a fixed 70%.
06-21-2024 05:48 AM
>....I want to set this manually, because
- That is not possible ,
M.
