Cisco packet tracer help
hiroyu
I am new to PT and taking the online intro course.
In the sector Video - Deploying Devices Example they connected home router to a webcam.
I tried connecting mine on my PT but it keep getting connection error: The cable cannot be connected to this port
Please help
see attached
Martin L
it is because WebCam is wireless one by default;  Click on Webcam, click on Advanced button in right-lower corner. This should add I/O Config tab to menu on top between Specs and Physical tabs. Go to I/O and add Network Ethernet adapter.
Also, you can Find and Use motion_detector.pkt sample file in your install folder; Also check PT samples files in \Cisco Packet Tracer 8.1.0\saves\04 IoT\Solution Examples
Regards, ML
**Please Rate All Helpful Responses **
19 Replies 19
Martin L
Regards, ML
Hi. i am trying cisco now and also have this error. I cannot see the add Network Ethernet Adapter. I added a screenshot. Hope for you assistance. Thanks
is this regular PT lab? yours ?  if this is PT activity lab (lab made by instructor), some things and tabs are limited/disabled so that he/she can grade your lab.  such file is password protected.
you can always attach PT file here but must be zip it first.
Regards, ML
oh that is why. yes i just started and following the tutorial. ok will just continue the course for now.
thanks for the quick reply!
This note means to say, set the "Network Adapter" field to the name of an Ethernet network in your topology space.  Specifically, set this to "PT-IOT-NM-1CE."  That's what worked for me.  Once this is done, the auto-connect "lightning bolt" button will work as seen in the video.
Hope this helps.
I noticed the default Webcam was wireless only after trying to use the automatic connection type tool to connect the Webcam to the Home Router/Wireless Router, finding in the I/O configuration tab, a small list of different Network Adapter types in the first drop down box. PT-IOT-NM-1W was selected and I stuck out searching for a defined list of each type so the best one can be chosen.
My best *guess* for the PT-IOT-NM prefix they all begin with would be: Packet Tracer, Internet of Things, Network Module, then your choices could possibly be: 1CE (single connection copper Ethernet?), 1CFE being single connection copper Fast Ethernet, 1CGE might be single connection copper Gigabit Ethernet, 1W single connection Wireless, 1W-AC single connection Wireless-AC connection, and 3G/4G could possibly be 3G or 4G Cellular Network connection.
Best wishes,
Best wishes,
th4201
Hello Martin
This option didn't work for me. I decided continue the course dismissing this part
Use PT-IOT-NM-1CE as Network Adapter.
Hola @sumomanu, gracias por compartir tus conocimientos. Gracias a su consejo, pude conectar mi dispositivo; de lo contrario, no lo habría logrado. Estaba a punto de rendirme .
Hi Martin,
Many thanks! it's working for me.
EP
There are many Network Adapters in the Network Adapter in that meniu.
Thanks so much, it has work for me too
Thanks so much bruh
