Portchannel question
grapevine
We have 3 Cisco IE-9320 in a stack. We have a Portchannel connecting to ESXI from switch 2 port 3 and switch 3 port 4
4 Po4(SU) - Gi2/0/3(P) Gi3/0/4(P).
Ports are in bundled.
GigabitEthernet2/0/3 media type is 10/100/1000BaseTX SFP
GigabitEthernet3/0/4  media type is 10/100/1000BaseTX
ESXI nic teaming is configured as Route based on IP hash.
Ping to esxi is dropping intermittently
SW01#sh run int Po4
Building configuration...
Current configuration : 127 bytes
interface Port-channel4
switchport trunk allowed vlan 16,18
switchport mode trunk
end
SW01#sh run int Gi2/0/3
Current configuration : 168 bytes
interface GigabitEthernet2/0/3
channel-group 4 mode on
end
SW01#sh run int Gi3/0/4
interface GigabitEthernet3/0/4
end
arp is incomplete for esxi in firewalls. please advise how to fix it
grapevine
We powered off switch one by one in the stack, then noticed if the ESXI was reachable. the issue was that once the switch got added to the stack, the ESXI went unreachable
We figured out the issue. We issued the command spanning-tree portfast trunk on the portchannel and the issue resolved
We also had an issue with SFP that connected to ESXI2, we replaced it and it resolved.
Thank you all for the support
24 Replies 24
Hello
If the ESXI teaming supports it change the PC both ends from a static to dynamic (LACP)
Kind Regards
Paul
ESXI's current license  doesn't support LACP
@grapevine hi, looks like configuration is ok. is there any specific ARP are you looking for?
do you have any test VM on esxi with IP address form VLAN16,18 to test?
and , did you configured teaming at vswitch in esxi?
Good luck
KB
It was working fine and stopped all of a sudden. I am not able to ping any vms inside the esxi. There are vms in vlan 16 and 18
In SW do
Show vlan brief <<- share this
MHM
Show interface trunk
Show switchport interface <PO>
Show switchport interface <g2/0/3 & g3/0/4>
Share this please
MHM
@grapevine ok. so its sudden issue. was there any changes on server side or switch side? and as @MHM Cisco World mentioned, can you share the vlan information from switch, and #sh etherchannel sum, and check if there is any VLAN changes at VSwitch in esxi.
Good luck
KB
No changes were made as far as I remember
Hello
On the cicso portchannel
int port 4
Kind Regards
Paul
Not show interface
Let see if port member and PO run as trunk not as access interface
MHM
I dont see show switchport interface command listed
PVW-CSW01#show switch?
switch
I found out something now
Switch 3 in the stack has rebooted. We saw this in the past when switch reboots and adds in the stack the connected esxi and servers go offline, server guys did some changes in the esxi and it came back online
Switch 03
Switch uptime : 18 hours, 39 minutes
Base Ethernet MAC Address :
Motherboard Assembly Number :
Motherboard Serial Number :
Model Revision Number : G0
Motherboard Revision Number : D0
Model Number : IE-9320-24T4X
System Serial Number :
Last reload reason : EHSA standby down
show interface switchport <<- sorry this order
MHM
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk (member of bundle Po4)
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: On
Access Mode VLAN: 1 (default)
Trunking Native Mode VLAN: 1 (default)
Administrative Native VLAN tagging: disabled
Voice VLAN: none
Administrative private-vlan host-association: none
Administrative private-vlan mapping: none
Administrative private-vlan trunk native VLAN: none
Administrative private-vlan trunk Native VLAN tagging: enabled
Administrative private-vlan trunk encapsulation: dot1q
Administrative private-vlan trunk normal VLANs: none
Administrative private-vlan trunk associations: none
Administrative private-vlan trunk mappings: none
Operational private-vlan: none
Trunking VLANs Enabled: 16,18
Pruning VLANs Enabled: 2-1001
Capture Mode Disabled
Capture VLANs Allowed: ALL
Protected: false
Unknown unicast blocked: disabled
Unknown multicast blocked: disabled
Vepa Enabled: false
App Interface: false
Appliance trust: none
Switchport: Enabled
Voice VLAN: none
Protected: false
Vepa Enabled: false
Switchport: Enabled
Voice VLAN: none
Protected: false
Vepa Enabled: false
