Cisco Packet Tracer Issues
29Terqlmn
2 Router 2 Switch 2 PC config.
PC A AND B -> R1 OK
PC A > B OK
R1 -> R2 OK
R1 -> Lo0 OK
I'm guessing its an issue with the route table. Any help appreciated.
Here are the router configs
hostname r1
enable secret 5 $1$mERr$9cTjUIEqNGurQiFU.ZeCi1
no ip domain-lookup
interface FastEthernet0/0
 no ip address
 duplex auto
 speed auto
interface FastEthernet0/0.10
 encapsulation dot1Q 10
 ip address 192.168.10.1 255.255.255.0
interface FastEthernet0/0.20
 encapsulation dot1Q 20
 ip address 192.168.20.1 255.255.255.0
interface FastEthernet0/0.99
 encapsulation dot1Q 99 native
 ip address 192.168.99.1 255.255.255.0
interface FastEthernet1/0
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 192.168.1.1 255.255.255.252
 clock rate 128000
interface Serial3/0
 no ip address
 shutdown
interface FastEthernet4/0
 no ip address
 shutdown
interface FastEthernet5/0
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.1.2
line con 0
 password 7 0822455D0A16
 logging synchronous
 login
line aux 0
line vty 0 4
 login
 transport input telnet
end
And the Router 2 configs
hostname Router
no ip domain-lookup
interface Loopback0
 ip address 200.100.50.25 255.255.255.0
interface Loopback1
 ip address 192.168.120.1 255.255.255.0
interface Loopback2
 ip address 192.168.121.1 255.255.255.0
interface Loopback3
 ip address 192.168.122.1 255.255.255.0
interface Loopback4
 ip address 192.168.123.1 255.255.255.0
 no ip address
 duplex auto
 speed auto
 shutdown
 no ip address
 duplex auto
 speed auto
 shutdown
interface Serial2/0
 ip address 192.168.1.2 255.255.255.252
interface Serial3/0
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
ip classless
ip route 0.0.0.0 0.0.0.0 Loopback0
line con 0
 logging synchronous
 login
line aux 0
line vty 0 4
 login
end
Borgenstrand
Old thread, but still gonna answer.
Based on what I could see, it is the ip route on the second router that is the problem. On the first router, it is sending everything through interface Serial2/0 but on the second router, it is sending everything to Loopback0. Which means that Router2 cannot get to Router1
TheRealBecks
<nothing>
