Cisco Packet Tracer Ping Issues
Taha879
Greeting,
I'm unable to Ping from PC1 to PC2, which displays "Request time out" always. But, can successfully Ping from PC2 to PC3.
Attached are all the screenshots below from Cisco Packet Tracer.
regards,
Taha1122334455
have a look at the attached file, I rebuilt your network. Check the settings and compare them with yours...
post the zipped Packet Tracer project (.pkt) file...
Thank you very much for reviewing my problem and sending the solutions. Actually, I accidently erased the IP address from static default gateway in PC1 global settings. After entering the PC1 router IP address in the static box, the ping command works properly.Capture.PNG
