Cisco Packet Tracer problem
electromechwork76909
Community Member
Good day all,
I a, presently working on packet tracer 7.3.1.0632 from the task given on Netacad assignment. Unfortunately my CO Server tower doesn't have some features, Example. No "Desktop, Attributes, Software/Service"  on its properties. Just "physical, Config and services".
Also, under config, there is no "Fastethernet0" too. Please kindly assist me as soon as possible on what to do so that i can complete the Lab task. Thanks.
for more clarity check the attached file 1 and 2 for the differences i am referring to.
Georg Pauwen
what is the lab task ? If you click on the Backbone and Cell Tower buttons, there should be a possibility to enter an IP address...is that what you are looking for ?
Martin L
There are 2 servers in PT; make sure you do not select Meraki one; just regular server
Regards, ML
**Please Rate All Helpful Responses **
