Cat 1000 switch, port-channel load balncing
chris.jinks
I'm trying to config the load-balancing mechanism for a port-channel on a Cat 1000 switch however it doesn't recognise the command
port-channel load-balance src-dst-ip
WAN-site-sw-A(config)#port-channel ?
auto LACP auto for the system
Any idea?
6 Replies 6
Joseph W. Doherty
Might not be supported with your IOS versions and/or licensed feature set.
What IOS version are you running and with what licenses?
Software is the latest i believe; 15.2(7)E2
Not sure on the license, its a C1000-24P-4G-L
Reza Sharifi
What is the output of "sh etherchannel load-balance"?
SW-A#show etherchannel load-balance
EtherChannel Load-Balancing Addresses Used Per-Protocol:
Non-IP: Source XOR Destination MAC address
IPv4: Combination of both SRC-DST-MAC and SRC-DST-IP
IPv6: Combination of both SRC-DST-MAC and SRC-DST-IP
Presumably, it is automatically doing load-balancing?
"Presumably, it is automatically doing load-balancing?"
That's unclear as in the reference Balaji provided we find "You also must set the load-distribution method to source-based distribution, so that any given source MAC address is always sent on the same physical port." although I didn't see a way to set the method, and it appears there's no additional choices. (Src balancing, as shown by your show command, can be fine for many-to-one, but no good for one-to-many. When no good, you still have redundancy.)
balaji.bandi
