Cisco Packet Tracer
JFGUDUD
 In this section, you must apply layer 3 redundancy, so the ISP router is always reachable. Do the following:
  1. Enable HSRP on the appropriate interface of each of the two Gateway routers.
  2. Assign highest HSRP priority to Gateway 1 (Active router)
  3. Ensure that Gateway 1 becomes the active HSRP router again when the links comes back up.
  4. Modify the default gateway on each PC to target the new HSRP router IP address.
  5. Ping from both PCs to the server to verify connectivity and take note of the paths followed by the packet. You may use PDA packets.
    6. Disable interface Gig0/0 on Gateway 1 and Ping from both PCs to the server to verify that connectivity is still available. The paths should be different from the last simulation.
    7. Re-enable interface Gig0/0 on Gateway 1 and Ping from both PCs to the server. Verify that the packets go back through Gateway 1.
What is your question?
change the default gateway on both PCs to 10.0.0.1, and use the configs below on the gateway routers:
Gateway_1#sh run
Building configuration...
Current configuration : 807 bytes
version 15.1
no service timestamps log datetime msec
no service timestamps debug datetime msec
hostname Gateway_1
ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX152438S2
spanning-tree mode pvst
interface GigabitEthernet0/0
ip address 10.0.0.2 255.0.0.0
duplex auto
speed auto
standby 1 ip 10.0.0.1
standby 1 priority 110
standby 1 preempt
interface GigabitEthernet0/1
ip address 11.0.0.1 255.0.0.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
log-adjacency-changes
network 10.0.0.0 0.255.255.255 area 0
network 11.0.0.0 0.255.255.255 area 0
ip classless
ip flow-export version 9
line con 0
line aux 0
line vty 0 4
login
end
Gateway_2#sh run
Current configuration : 764 bytes
version 15.1
hostname Gateway_2
ip cef
no ipv6 cef
license udi pid CISCO2901/K9 sn FTX1524BEX4
ip address 10.0.0.3 255.0.0.0
duplex auto
speed auto
ip address 12.0.0.1 255.0.0.0
duplex auto
speed auto
interface Vlan1
no ip address
shutdown
router ospf 1
network 12.0.0.0 0.255.255.255 area 0
ip classless
line con 0
line aux 0
line vty 0 4
login
end
how do i enable an hsrp on the pkt sent above?
not sure what you mean. What do you want to enable ? Did you configure the routers as stated ? The exec command:
sh standby
tells you the status of the HSRP.
