Cisco Pix 501 random connectivity
emanueled1
Hello. I am having some troubles with my CISCO PIX 501 configuration.
Since a few month ago I started to get random disconnections on my network (from inside to outside). The machines can ping the DC or the Pix but cannot surf over the internet. The only way to make them to go outside is a Pix restart.
My configuration is the following:
as-pix(config)# show config
: Saved
: Written by enable_15 at 09:23:07.033 UTC Tue Jun 3 2014
PIX Version 6.3(3)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
enable password 8Ry34retyt7RR564 encrypted
passwd 2fvbbfgdI.2KUOU encrypted
hostname as-pix
domain-name as.local
fixup protocol dns maximum-length 512
fixup protocol esp-ike
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol pptp 1723
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
fixup protocol tftp 69
names
access-list acl_out permit icmp any any
access-list acl_out permit ip any any
access-list acl_out permit tcp any any
access-list outside_access_in permit esp any any
access-list outside_access_in permit udp any eq isakmp any
access-list outside_access_in permit udp any eq 1701 any
access-list outside_access_in permit udp any eq 4500 any
access-list outside_access_in permit ip any any
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside 10.10.10.2 255.255.255.0
ip address inside 192.168.100.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm history enable
arp timeout 14400
global (outside) 1 10.10.10.8-10.10.10.254
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
access-group outside_access_in in interface outside
access-group acl_out in interface inside
route outside 0.0.0.0 0.0.0.0 10.10.10.1 0
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
http 192.168.10.2 255.255.255.255 inside
http 192.168.10.101 255.255.255.255 inside
http 192.168.100.2 255.255.255.255 inside
no snmp-server location
no snmp-server contact
snmp-server community public
no snmp-server enable traps
floodguard enable
sysopt connection permit-ipsec
isakmp nat-traversal 20
telnet timeout 5
ssh 192.168.10.101 255.255.255.255 inside
ssh timeout 60
console timeout 0
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
terminal width 80
Cryptochecksum:7f9bda5e534eaeb1328ab08a3c4d28a
Do you have any advice? I am not getting what is wrong with my configuration.
My DC is 192.168.100.2 and the network mask is 255.255.255.0
The network configuration is set up to set the Gateway IP to 192.168.100.1 (which is the PIX 501).
I have around 50+ peers on the internal network.
Any help is apprecciate.
Hello
Do you have a license for 50+ users?
Post the output of - Show version
res
Paul
Kind Regards
Paul
Hello
res
Paul
Kind Regards
Paul
Hello Paul, how can I check it?
The number of the peers of my network is not stable everyday (can vary depending from the number of the employees at office that day and the number of personal devices connected to the network...).
I did not notice your suggestion.
Here you are the output:
as-pix# show version
Cisco PIX Firewall Version 6.3(3)
Cisco PIX Device Manager Version 3.0(1)
Compiled on Wed 13-Aug-03 13:55 by morlee
as-pix up 2 hours 59 mins
Hardware:   PIX-501, 16 MB RAM, CPU Am5x86 133 MHz
Flash E28F640J3 @ 0x3000000, 8MB
BIOS Flash E28F640J3 @ 0xfffd8000, 128KB
0: ethernet0: address is 000f.908f.2847, irq 9
1: ethernet1: address is 000f.908f.2848, irq 10
Licensed Features:
Failover:                    Disabled
VPN-DES:                     Enabled
VPN-3DES-AES:                Enabled
Maximum Physical Interfaces: 2
Maximum Interfaces:          2
Cut-through Proxy:           Enabled
Guards:                      Enabled
URL-filtering:               Enabled
Inside Hosts:                50
Throughput:                  Unlimited
IKE peers:                   10
This PIX has a Restricted (R) license.
Is it limited to 50 hosts?
How can I raise this limit?
Thanks.
Hello
You need to purchase this of a cisco reseller or cisco direct but I am afraid cisco pix are now EOL so you may have to upgrade your PIX FW to an ASA FW or if that isn't palpable and finances are tight maybe remove the pix altogether and depending on your existing routers male/model apply IOS security to the router.
res
Paul
Kind Regards
Paul
