Cisco PIX Crude Traffic Load Balance
Nicholas Beard
Hi all,
Im looking at performing a type of crude load balancing from a single Cisco PIX.  I have a scenario whereby I have two ADSL routers directly connected to two seperate external interfaces on the Cisco PIX.  I am aware that the device does not support any form of Policy Based Routing therefore i plan to implement the following -
route outside 0.0.0.0 0.0.0.0 Router 1 metric 1
route outside 0.0.0.0 0.0.0.0 Router 2 metric 2
nat (inside) 1 0 0
global (outside 1) 1 interface
global (outside 2) 1 interface
static (outside 1,inside) tcp 0.0.0.0 www 0.0.0.0 www netmask 0.0.0.0
static (outside 2,inside) tcp 0.0.0.0 smtp 0.0.0.0 smtp netmask 0.0.0.0
I believe this should force the Cisco PIX to perform a destination NAT based on the services specified and therefore cause it to ignore the metrics of the static routes.
Am i correct in the assumption that the NAT will decide the necessary routed interface, based on the rule specified above?
Thanks all
andrew.prince
Level 10
Level 10
You are not performing desintation NAT - by specificy the TCP port you are perfoming PAT.
and all the config is doing is forcing the WWW traffic out of 1 interface and SMTP out the other.
HTH>
andrew.prince
Level 10
Level 10
HTH>
