Cisco police command to reserve bandwidth
cssam
    hi,
I want to configure police command in Qos to reserve bandwidth since bandwidth command not supported in my linecard.
Requirement is police command has to reserve bandwidth, if exceeding  bandwidth reservation it should go to class default.
Not sure about this.
But i can see that there are additional options in rate command . like you can define values as packets as well as bps.
Hope this helps
Mahesh
Mahesh Gohil
Level 7
Level 7
Please find config
class-map PRIORITY
match ip precedence 5 <<<< this is just an example you can change value/or call access-list
let's assume you have 2mb pipe and you want to reserve 512k
policy-map PRIORITY
class-map PRIORITY
police cir 512000 96000 192000 conform-action transmit exceed-action set-prec-transmit 0
class-map class-default
police cir  1536000 288000 576000 conform-action transmit exceed-action drop
policy-map PARENT
police cir  2048000 384000 768000 conform-action transmit exceed-action drop
above (parent) ensure that if priority class is not using bandwidth it will be used by class-default class
Mahesh
thanks mahesh,
Just to confirm as mentioned below, if bandwdith exceeding 512 kbps, will it go to class default?
Can i use police rate instead of cir..
Hope this helps
Mahesh
