Cisco Remote Syslog on different UDP/TCP Port,, possible?
DotTest37
I have a couple of Cisco 2960's sending syslog messages to a remote syslog-ng on port 514 (standard).
I need to set another Swtich so it sends traffic to the same syslog server but on another UDP port (such as 714),, is that possible,?
I cannot find the option on the documentation.
Thanks!
10 Replies 10
Peter Paluch
Try using:
logging host X.X.X.X transport udp port 714
Best regards,
Peter
Hello Peter
Switch(config)#logging 192.168.200.223 transport udp port 714
% Invalid input detected at '^' marker.
According to the documentation, the command is >  logging host <
where host  is the destination IP.
Doestn say anything about ports or protocol.  :-(
The command Peter provided is correct.
see example:
Switch(config)#logging host 192.168.200.223 transport udp port 174
Switch(config)#
can you provide a model number for your 2960?
cisco WS-C2960G-48TC-L (PowerPC405) processor (revision C0) with 61440K/4088K bytes of memory
C2960 Software (C2960-LANBASE-M), Version 12.2(35)SE5
Maybe my IOS is too old.
In the global can you do an l and ? to see the options?
Switch(config)#l?
l2protocol-tunnel  lacp   li-view  license
line               link   lldp     location
logging            login
Switch(config)#l
returns:
lacp  line  link  logging  login
It appear that the 2960s do not support this command
here the reference guide for 12.2(55)
http://cavalcante.us/Cisco/Catalyst%202960%20and%202960%20-S%20Switch%20Command%20Reference,%20Release%2012.2%2855%29SE.pdf
:-(  Thats what I was afraid of.
I didnt see it on the Documentation.
I might have then to try another trick, maybe a Middleware Syslog, with some filters and then a forward to another port.
Thats a shame it doesnt support it.
You can accomplish what you need by filtering on the receiving end for that one switch. Here's a link to a very good whitepaper on syslog management:
http://www.cisco.com/en/US/technologies/collateral/tk869/tk769/white_paper_c11-557812.html
You can easily set up syslog-ng or rsyslog to filter out messages from that device.
Hi Peter.
This command works with the Cisco Nexus 9k?
