Cisco Router and Switch
tiuhenrick
Please help me find this Cisco Router and Switch with specs below:
SPECIFICATIONS for Router
Must have 2 10/100/1000 Ethernet fixed interfaces ports
On board encrption
Support up to 1500 VPN tunnels with the AIM-EPEII_PLUS Module
Antivirus defense support through Network Admission Control (NAC)
Intrusion Prevention as well as stateful CISCO IOS Firewall support and many more essential security features
Analog and digital voice call support
Dedicated Extension Voice Module slot
Optional voice mail support
Should have 3 internal slots for PVDM's to support voice transcoding
Optional support for Cisco CallManager Express for local call processing in stand alone business for up to 96 IP phones
Optional support for Survival Remote Site Telephony support for local processing in small enterprise branch offices for up to 96 IP phone
Should have 1000MB DRAM and 256MB flash
Should provide 4 slots, each slot can support HWIC, WIC, VIC or VWIC type modules
Must support multiple optional types of Ethernet and serial connections
Should support one Network-Module Slot
Must have Integrated hardware-Based Encryption
Must support DES, 3DES, AES 128, AES 192 and AES 256 VPN hardware acceleration or motherboard
Must support dynamic multipoint VPN
Must support Group Encrypted Transport VPN
Must support Network admission control
Must support access control list
Must support committed access rate.
Must support one or two onboard USB 1.1 ports
Must support the optional security modules (IPS,VPN, content engine network modules)
SPECIFICATIONS for switch
32 Giga bps forwarding bandwith
24 port 10/100
Forwarding rate 38.7Mpps for the 128 MB DRAM
32 MB Flash Memory
Configurable up to 12,000 MAC Addresses
Configurable up to 11,000 unicast routes
Configurable up to 1000 IGMP groups and multicast routes
Configurable maximum transmission unit (MTU) of up to 9000 bytes with a maximum Ethernet frame size of 9018 bytes (Jumbo frames) for bridging on Gigabit Ethernet ports and up to 1546 bytes for bridging of Multi protocol Label switching (MPLS) tagged frames on 10/100 ports
Should support power over Ethernet POE on all ports on all access switches
The 24 ports switches should have 2 SFP
It should support 802.1 x protocol
The switches should use internal SFP interconnect
It should support all layer three protocols and support ACL's equal path routing and advanced spanning tree feature for higher redundancy.
thanks in advance!
Edison Ortiz
2800ISR
http://www.cisco.com/en/US/products/ps5854/index.html
3560G-24PS (there isn't a 10/100 switch with the required forwarding rate and PoE support).
http://www.cisco.com/en/US/products/hw/switches/ps5528/prod_models_comparison.html
HTH,
__
Edison.
Just make sure it's at least a 2821. Anything lower has 10/100 ports.
