CISCO Router fiber connection
newIntern
Hello.
I'm looking for a cisco router to authenticate the internet provider and that allows fiber optic communication. Those are the only two really important features for the project. What do you recommend me?
Hello
Checkout meraki mx , fw & rtr in one - Cisco meraki mx
Kind Regards
Paul
8 Replies 8
balaji.bandi
what kind of throughput here ?
Cisco have many line of Routers - small to big level.
https://www.cisco.com/c/en/us/products/routers/branch-routers/index.html
BB
Thanks for your response.
Sorry for only responding now.
The throughput is 100 Mbps.
I did some research and saw for example Cisco Catalyst 8200 Series Edge Platform. They have at least 2 such interfaces. However, I don't want to spend a lot of money on equipment that would be restricted to the function described in the post.
Any suggestions?
any router with an SFP for a fiber optic connection will do. What do you mean exactly by 'authentication' ? All router support PPP/PAP/CHAP (if that is what you mean).
Have a look at the ISR 1100 routers:
--> All 1100-8P and 1100-4P platforms model have one 10/100/1000 Ethernet port that can support Small Form-Factor Pluggable (SFP)-based connectivity in addition to RJ-45 connections, enabling fiber or copper connectivity.
Here is the link to the data sheet:
https://www.cisco.com/c/en/us/products/collateral/routers/1000-series-integrated-services-routers-isr/datasheet-c78-739512.html
Sorry for only responding now. I went to see the specifications of this series of routers from CISCO and saw that they only have one sfp interface. The router I need would have to have at least two sfp interfaces. I did some research and saw for example Cisco Catalyst 8200 Series Edge Platform. They have at least 2 such interfaces. However, I don't want to spend a lot of money on equipment that would be restricted to the function described in the post. Are there any cheaper suggestions?
how much money are you willing to spend ?
Around US$ 3000.
But you can suggest of any price and I will evaluate the pros and cons.
tough one. I looked around, a lot, but could not really find a Cisco dual SFP WAN router.
The only one (not Cisco), for a decent price,  I could find was this one:
https://www.tp-link.com/nl/business-networking/omada-sdn-router/er8411/
Hello
Kind Regards
Paul
