Cisco router randomly not serving DHCP responses
ali.jawad
I got a Cisco router, it is also the DHCP server of my network the detail are below.
For some reason the server randomly stops serving IPs to workstations, even a repair conection does not work. Some computers have a valid IP but it does not get renewed.
Router#show version
Cisco IOS Software, 2800 Software (C2800NM-ADVIPSERVICESK9-M), Version 12.4(17b)
, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2008 by Cisco Systems, Inc.
Compiled Tue 26-Feb-08 01:46 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
I did enable debug and I got :
Adding to the above I got the following debug info...as you can see below the mac address 0016.d490.8e9a is trying to get an IP but it is getting the answer..DHCPD: Allocate an address without class information while 0100.40f4.9689 got 192.168.0.204
Router#
*Apr 16 14:36:43.375: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
interface FastEthernet0/1.
*Apr 16 14:36:43.375: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:36:43.647: %HA_EM-6-LOG: CLIAccounting: terminal monitor
*Apr 16 14:37:00.535: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:37:00.535: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:37:05.375: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:37:05.379: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:37:16.375: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:37:16.375: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:37:29.375: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:37:29.379: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:37:42.375: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:37:42.375: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:37:43.551: DHCPD: DHCPINFORM received from client 0100.40f4.9689.ec (
192.168.0.204).
*Apr 16 14:37:43.551: DHCPD: Sending DHCPACK to client 0100.40f4.9689.ec (192.16
8.0.204).
*Apr 16 14:37:43.551: DHCPD: unicasting BOOTREPLY to client 0040.f496.89ec (192.
168.0.204).
*Apr 16 14:37:46.555: DHCPD: DHCPINFORM received from client 0100.40f4.9689.ec (
192.168.0.204).
*Apr 16 14:37:46.555: DHCPD: Sending DHCPACK to client 0100.40f4.9689.ec (192.16
8.0.204).
*Apr 16 14:37:46.555: DHCPD: unicasting BOOTREPLY to client 0040.f496.89ec (192.
168.0.204).
*Apr 16 14:38:00.371: DHCPD: DHCPDISCOVER received from client 0016.d490.8e9a on
*Apr 16 14:38:00.371: DHCPD: Allocate an address without class information (192.
168.0.0)
*Apr 16 14:38:07.115: DHCPD: DHCPINFORM received from client 0100.1676.6d3b.5e (
192.168.0.182).
*Apr 16 14:38:07.115: DHCPD: Sending DHCPACK to client 0100.1676.6d3b.5e (192.16
8.0.182).
*Apr 16 14:38:07.115: DHCPD: unicasting BOOTREPLY to client 0016.766d.3b5e (192.
168.0.182).
*Apr 16 14:38:10.115: DHCPD: DHCPINFORM received from client 0100.1676.6d3b.5e (
192.168.0.182).
*Apr 16 14:38:10.115: DHCPD: Sending DHCPACK to client 0100.1676.6d3b.5e (192.16
8.0.182).
*Apr 16 14:38:10.115: DHCPD: unicasting BOOTREPLY to client 0016.766d.3b5e (192.
168.0.182).
Please advice. The pool is:
#show ip dhcp pool
Pool centrale :
Utilization mark (high/low) : 100 / 0
Subnet size (first/next) : 0 / 0
Total addresses : 254
Leased addresses : 143
Pending event : none
1 subnet is currently in the pool :
Current index IP address range Leased addr
0.0.0.0 192.168.0.1 - 192.168.0.254 143
http://pastebin.com/mc416229
John Blakley
What does your actual dhcp scope look like?
Can you paste the section "ip dhcp pool "?
HTH,
John
HTH, John *** Please rate all useful posts ***
