Marking problem DSCP bits on Cat 6500 with native IOS
c-naumann
I'd like to mark incoming UDP packets with DSCP values on a 6509 with Sup720 3BXL. Incomming interface is a WS-X6748-GE-TX
What I did is
mls qos
class-map match-any UDPKRAM
match access-group 100
policy-map UDPKRAM_AF21
class UDPKRAM
set ip dscp af21
access-list 100 permit udp any any
Interface of the incoming UDP packets:
service-policy input UDPKRAM_AF21
R4# sh mls qos ip gi3/3
[In] Policy map is UDPKRAM_AF21 [Out] Default.
QoS Summary [IPv4]: (* - shared aggregates, Mod - switch module)
Int Mod Dir Class-map DSCP Agg Trust Fl AgForward-By AgPoliced-By
Id Id
Gi3/3 5 In UDPKRAM 18 2 No 0 88192 0
The problem is, the DSCP value of outgoing packets is 0, i can't see marked packets, not in wireshark on the outgoing line and not at the next hop. Any ideas where the marking is lost?
7 Replies 7
andrew.prince
Level 10
Level 10
As far as I have found the 65xx platform does not support the marking of layer 3 IP header QoS.
HTH>
Jon Marshall
Can you post
1) The full interface configuration of the interface that you have applied the policy map
2) The cos-to-DSCP map, the DSCP-cos map and the DSCP mutation map
Jon
I can :-)
interface GigabitEthernet3/3
description Link zum VMware FTP
ip address 10.9.4.5 255.255.255.252
load-interval 30
no cdp enable
no mop enabled
end
Cos-dscp map:
cos: 0 1 2 3 4 5 6 7
dscp: 0 8 16 24 32 40 48 56
Dscp-cos map: (dscp= d1d2)
d1 : d2 0 1 2 3 4 5 6 7 8 9
0 : 00 00 00 00 00 00 00 00 01 01
1 : 01 01 01 01 01 01 02 02 02 02
2 : 02 02 02 02 03 03 03 03 03 03
3 : 03 03 04 04 04 04 04 04 04 04
4 : 05 05 05 05 05 05 05 05 06 06
5 : 06 06 06 06 06 06 07 07 07 07
6 : 07 07 07 07
and there is no mutation map. Hope that helps
Carsten
Carsten
If you want to preserve the DSCP setting in your packets you need to enable this globally on your switch
6500(config)# no mls qos rewrite ip dscp
Jon
Hey Jon,
the main target is not to keep only the DSCP bits. It is:
Mark "clean" pakets on the incomming port, route them, and get the marked pakets on the outgoing port.
Keeping the dscp bits works, but not marking then in the incomming linecard.
To disable ip dscp rewriting hasn't changed anything on that :-/
other suggestions?
thanks Carsten
Carsten
Sorry but just to clarify.
You want packets arrving on gi3/5 interface to have a DSCP marking of AF21.
If the packet already has a DSCP marking do you want to replace it with AF21 or keep the marking.
What about packets that do not match your acl ie. no UDP packets.
You want packets that have entered on gi3/5 and been marked to AF21 to keep that marking when exiting any other interface on the switch ?
The next hop ? what is the port on the 6500 that is used to forward on the traffic configured as ?
What version of software are you running ?
Jon
I want that any udp packets arriving at gi3/3 get DSCP AF21, all others (that do not match the acl) should not be touched.
Yes the marking should be kept when exiting any other interface. The port that forwards traffic is gi 5/1
interface GigabitEthernet5/1
ip address 10.7.2.2 255.255.255.252
mpls traffic-eng tunnels
mpls ip
ip rsvp bandwidth 75000 sub-pool 30000
end
I'm running Version 12.2(33)SXI Adv-Ent
and the core problem is that I'm confused why the counters in the policy map are rising while no marked packets are leaving the Catalyst ;-)
Carsten
