Cisco RV320 Inter VLAN routing not working
kashif.ali.uk
I am having a problem where I cannot get the inter VLAN routing working correctly and I was hoping someone can help. I had all this working with another router so I am happy that the switch configuration is correct and its something to do with the router. I have provided the configuration information below:
VLAN ID 1: 192.168.1.0/24 - Router: 192.168.1.254
VLAN ID 10: 192.168.10.0/24 - Router: 192.168.10.254
VLAN ID 20: 192.168.20.0/24 - Router: 192.168.20.254
VLAN ID 30: 192.168.30.0/24 - Router: 192.168.30.254
VLAN ID 40: 192.168.40.0/24 - Router: 192.168.40.254
VLAN ID 50: 192.168.50.0/24 - Router: 192.168.50.254
LAN PORT 1 = 192.168.1.0/24 (Office LAN)
LAN PORT 4 = VLAN TRUNK
I can ping the router address (10,20,30,40,50).254 from the 192.168.1.x hosts, however I cannot pings hosts on the .10 - .20  networks. The router it self can ping hosts on the .10 and .20 networks fine.
I have the inter VLAN routing enabled for the two networks I care about 10 and 20 so I am not sure why this isn't working. How can the router ping the hosts on all networks but the hosts cannot ping across subnets.
Please see images attached for Router configuration.
0 Replies 0
