Cisco SCP not working
Hasrat Bhanot
I am trying to backup config automatically using SCP command
commands I am using
archive
path scp://user:pass@server/$h
write-memory
I am not getting any error message but when I do show archive I get this
The maximum archive configurations allowed is 10.
The next archive file will be named scp://user:pass@80.76.122.134/rtr01-<timestamp>-1
Archive #  Name
   1        :Error - No such file or directory <- Most Recent
   2        :Error - No such file or directory
   7
   8
   9
Note:- My username and password is correct as when I do a manual backup it works, and Also the server is a Linux box and at remote location
thanks
Steve Fuller
Level 9
Level 9
There's nothing wrong with your configuration as I've just tried that exact configuration on two different routers and it works fine.
When you say a manual backup works without issue do you mean it works if you execute a copy run scp://user@pass:80.76.122.134/ command directly from the CLI?
If that's the case then it's possible that this is a bug. What is the platform and the IOS version you're running?
Yes copy running config commands works fine
Router I am workin is Cisco 1900 version 15.2(3)
