CISCO SDM
mbaylis
Level 3
Level 3
I am wanting to use Cisco SDM on 2 Cisco 2621XM routers in a lab enviroment. I am wanting to know which software vesion would be compatable to work on these routers. Can anyone help please. I am preparing for my ISCW exam and would like to gain some practical experience with SDM. My current IOS version does not support SDM. Thanks
keeleym
Level 9
Level 9
Hi There
If you check out the release notes fro your version of SDM it should tell you which version of IOS is required.
Here is a link to the release notes for SDM,
http://www.cisco.com/en/US/products/sw/secursw/ps5318/prod_release_notes_list.html
Hope that helps.
Best Regards,
Michael
