cisco sg250 switch for network access control
benv
i am deploying a 3rd party nac solution with a cisco sg250 10port switch
on the gui interface of the cisco sg250 switch i see 802.1x configuration which was properly configured
however when a user connects to the interface of the switch for 802.1x, on the 3rd party nac solution i see radius authentication rejected for username\domain
please advise if the cisco sg250 switch is considerable for 802.1x or just has basic 802.1x functionality
thanks
2 Accepted Solutions
pieterh
>>> on the 3rd party nac solution i see radius authentication rejected for username\domain <<<
looks like the switch is talking properly to the 3rd party NAC device
but the radius request from this device to AD gets a "rejected" response
-> the NAC profile is not properly
matchet or the user does not belong to the correct group to use NAC
-->> check your AD setitngs (not switch)
7 Replies 7
balaji.bandi
how is your user source configured on the NAC (is this from AD?)
other than just basic config on the switch side and switch added to your NAC, that should work as expected :
below for reference in case you missed any options - as per the message look like far end issue (I am in guess)
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-220-series-smart-switches/smb5357-configure-802-1x-port-authentication-on-the-cisco-sx220-seri.html
BB
Thank you balaj
user source is from AD
We have done the configuration based on that article you share
However we are not completely sure if the cisco SG250 switch is compatible for an 802.1x
as per the switch concerns the switch capable of 802.1x, you need to check with NAC ( I am sure they do support I guess)
i see radius authentication rejected for username\domain   - this means the request was processed and failed somewhere in the path.
BB
Thank you
This article you posted is for SX 220 will the same configuration work for SG250?
Also while reading the article below it appears the SG250 might work for radius auth but definitely not for VLAN Assignment
https://community.cisco.com/t5/small-business-switches/radius-supplied-vlans-for-sg250-switches/td-p/4144726/page/2
pieterh
Thank you for you response
yes you are correct we had issues with the AD connection this is now resolved
