Cisco SG300 ACL Problem with outside private network
olivier.guenet
I have a problem with ACLs on a SG300-52 (Layer3 mode).
In fact, I have created ACLs to filter trafic between vlans, and permit Internet access. All this is working fine.
However, I have VPN distant with private IP Address (192.168.3.0/24 for example) routed by my firewall. If I activate an ACL on the SG300, no trafic is allowed to pass through even if it an permit ip any any rule applied!
I have tested to change my external network to 1.1.1.0/24, and all is working fine...
Is the SG300 filtering outside private networks? Is there a possibility to disable that?
If not, is it a bug?
Thanks for your help
10 Replies 10
Seb Rupik
Hi there,
Can you attached the SG300 config with desired ACL present and applied to the correct interface?
cheers,
Seb.
this is the switch configuration :
config-file-header
SW3-RG-1
v1.4.8.6 / R800_NIK_1_4_202_008
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
spanning-tree priority 0
bridge multicast filtering
vlan database
vlan 10-13,100-103,200-201,250,254,1000-1002
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
no lldp run
system router resources ip-entries 256
ip dhcp relay address 192.168.1.14
ip dhcp relay enable
no boot host auto-config
no bonjour enable
bonjour interface range vlan 1
ip access-list extended USERS-INVITES
permit ip any 192.168.1.14 0.0.0.0 ace-priority 20
permit ip any 10.1.0.7 0.0.0.0 ace-priority 40
permit ip any 10.1.0.11 0.0.0.0 ace-priority 60
permit ip any 172.16.44.128 0.0.0.0 ace-priority 80
permit ip any 192.168.254.0 0.0.0.255 ace-priority 100
deny ip any 192.168.0.0 0.0.255.255 ace-priority 120
deny ip any 172.16.0.0 0.0.31.255 ace-priority 140
deny ip any 10.0.0.0 0.255.255.255 ace-priority 160
exit
ip access-list extended SRV-FORMATION
permit ip any 192.168.1.14 0.0.0.0 ace-priority 780
permit ip any 10.1.0.7 0.0.0.0 ace-priority 800
permit ip any 10.1.0.11 0.0.0.0 ace-priority 820
permit ip any 10.1.0.0 0.0.0.255 ace-priority 840
permit ip any 192.168.1.0 0.0.0.255 ace-priority 860
permit ip any 172.16.44.0 0.0.0.255 ace-priority 880
permit ip any 172.31.0.0 0.0.255.255 ace-priority 900
permit ip any 172.16.44.248 0.0.0.7 ace-priority 920
permit ip any 192.168.254.0 0.0.0.255 ace-priority 940
deny ip any 192.168.0.0 0.0.255.255 ace-priority 960
deny ip any 172.16.0.0 0.0.31.255 ace-priority 980
deny ip any 10.0.0.0 0.255.255.255 ace-priority 1000
exit
ip access-list extended BAC-A-SABLE
permit ip any 192.168.1.14 0.0.0.0 ace-priority 1020
permit ip any 10.1.0.7 0.0.0.0 ace-priority 1040
permit ip any 10.1.0.11 0.0.0.0 ace-priority 1060
permit ip any 10.1.4.0 0.0.0.255 ace-priority 1080
permit ip any 172.31.0.0 0.0.255.255 ace-priority 1100
permit ip any 172.16.44.248 0.0.0.7 ace-priority 1120
permit ip any 192.168.254.0 0.0.0.255 ace-priority 1140
deny ip any 192.168.0.0 0.0.255.255 ace-priority 1160
deny ip any 172.16.0.0 0.0.31.255 ace-priority 1180
deny ip any 10.0.0.0 0.255.255.255 ace-priority 1200
exit
ip access-list extended USERS-FORMATION
permit ip any 192.168.1.14 0.0.0.0 ace-priority 1220
permit ip any 10.1.0.7 0.0.0.0 ace-priority 1240
permit ip any 10.1.0.11 0.0.0.0 ace-priority 1260
permit ip any 172.31.0.0 0.0.255.255 ace-priority 1280
permit ip any 10.1.0.0 0.0.0.255 ace-priority 1300
permit ip any 10.1.4.0 0.0.0.255 ace-priority 1320
permit ip any 10.1.1.0 0.0.0.255 ace-priority 1340
permit ip any 192.168.254.0 0.0.0.255 ace-priority 1360
deny ip any 192.168.0.0 0.0.255.255 ace-priority 1380
deny ip any 172.16.0.0 0.0.31.255 ace-priority 1400
deny ip any 10.0.0.0 0.255.255.255 ace-priority 1420
exit
ip access-list extended AFFICHAGE-DYN
permit ip any 192.168.1.14 0.0.0.0 ace-priority 2000
permit ip any 192.168.1.12 0.0.0.0 ace-priority 2020
permit ip any 192.168.1.15 0.0.0.0 ace-priority 2040
permit ip any 10.1.3.0 0.0.0.255 ace-priority 2060
permit ip any 172.16.44.0 0.0.0.255 ace-priority 2080
permit ip any 192.168.254.0 0.0.0.255 ace-priority 2100
deny ip any 192.168.0.0 0.0.255.255 ace-priority 2120
deny ip any 172.16.0.0 0.0.31.255 ace-priority 2140
deny ip any 10.0.0.0 0.255.255.255 ace-priority 2160
exit
ip access-list extended JSEC
permit ip any 192.168.1.14 0.0.0.0 ace-priority 2180
permit ip any 192.168.1.12 0.0.0.0 ace-priority 2200
permit ip any 192.168.1.15 0.0.0.0 ace-priority 2220
permit ip any 10.1.2.0 0.0.0.255 ace-priority 2240
permit ip any 172.16.44.0 0.0.0.255 ace-priority 2260
permit ip any 192.168.254.0 0.0.0.255 ace-priority 2280
deny ip any 192.168.0.0 0.0.255.255 ace-priority 2300
deny ip any 172.16.0.0 0.0.31.255 ace-priority 2320
deny ip any 10.0.0.0 0.255.255.255 ace-priority 2340
exit
ip access-list extended VIDEO-PROJ
permit ip any 192.168.1.14 0.0.0.0 ace-priority 2360
permit ip any 192.168.1.12 0.0.0.0 ace-priority 2380
permit ip any 192.168.1.15 0.0.0.0 ace-priority 2400
permit ip any 10.1.1.0 0.0.0.255 ace-priority 2420
permit ip any 172.16.44.0 0.0.0.255 ace-priority 2440
permit ip any 172.13.31.0 0.0.255.255 ace-priority 2460
permit ip any 172.16.44.248 0.0.0.7 ace-priority 2480
permit ip any 192.168.254.0 0.0.0.255 ace-priority 2500
deny ip any 192.168.0.0 0.0.255.255 ace-priority 2520
deny ip any 172.16.0.0 0.0.31.255 ace-priority 2540
deny ip any 10.0.0.0 0.255.255.255 ace-priority 2560
exit
ip access-list extended USERS-PRODUCTION
permit ip any 192.168.1.14 0.0.0.0 ace-priority 2760
permit ip any 192.168.1.12 0.0.0.0 ace-priority 2780
permit ip any 192.168.1.15 0.0.0.0 ace-priority 2800
permit ip any 172.16.44.0 0.0.0.128 ace-priority 2820
permit ip any 10.1.2.0 0.0.0.255 ace-priority 2840
permit ip any 10.1.1.0 0.0.0.255 ace-priority 2860
permit ip any 10.1.3.0 0.0.0.255 ace-priority 2880
permit ip any 10.1.0.0 0.0.0.255 ace-priority 2900
permit ip any 192.168.1.0 0.0.0.255 ace-priority 2920
permit ip any 192.168.254.0 0.0.0.255 ace-priority 2940
deny ip any 192.168.0.0 0.0.255.255 ace-priority 2960
deny ip any 172.16.0.0 0.0.31.255 ace-priority 2980
deny ip any 10.0.0.0 0.255.255.255 ace-priority 3000
exit
ip access-list extended SRV-PRODUCTION
permit ip 192.168.1.14 0.0.0.0 any ace-priority 3020
permit ip 192.168.1.12 0.0.0.0 any ace-priority 3040
permit ip 192.168.1.15 0.0.0.0 any ace-priority 3060
permit ip any 192.168.1.0 0.0.0.255 ace-priority 3080
permit ip any 172.16.44.0 0.0.0.255 ace-priority 3100
permit ip any 10.1.0.0 0.0.0.255 ace-priority 3120
permit ip any 172.16.44.248 0.0.0.7 ace-priority 3140
permit ip any 192.168.254.0 0.0.0.255 ace-priority 3160
deny ip any 192.168.0.0 0.0.255.255 ace-priority 3180
deny ip any 172.16.0.0 0.0.31.255 ace-priority 3200
deny ip any 10.0.0.0 0.255.255.255 ace-priority 3220
exit
ip access-list extended USERS-SI
permit ip any 192.168.1.14 0.0.0.0 ace-priority 3240
permit ip any 192.168.1.12 0.0.0.0 ace-priority 3260
permit ip any 192.168.1.15 0.0.0.0 ace-priority 3280
permit ip any 172.16.44.248 0.0.0.7 ace-priority 3300
permit ip any 192.168.44.0 0.0.0.255 ace-priority 3320
permit ip any 192.168.1.0 0.0.0.255 ace-priority 3340
permit ip any 10.1.44.0 0.0.0.255 ace-priority 3360
permit ip any 10.1.1.0 0.0.0.255 ace-priority 3380
permit ip any 10.1.4.0 0.0.0.255 ace-priority 3400
permit ip any 192.168.0.0 0.0.0.255 ace-priority 3420
permit ip any 10.1.0.0 0.0.0.255 ace-priority 3440
permit ip any 192.168.254.0 0.0.0.255 ace-priority 3460
permit ip any 192.168.2.0 0.0.0.255 ace-priority 3480
permit ip any 192.168.3.0 0.0.0.255 ace-priority 3500
permit ip any 192.168.4.0 0.0.0.255 ace-priority 3520
permit ip any 192.168.5.0 0.0.0.255 ace-priority 3540
deny ip any 192.168.0.0 0.0.255.255 ace-priority 3560
deny ip any 172.16.0.0 0.0.31.255 ace-priority 3580
deny ip any 10.0.0.0 0.255.255.255 ace-priority 3600
exit
ip access-list extended SRV-SERVICES
permit ip any 192.168.1.14 0.0.0.0 ace-priority 3620
permit ip any 192.168.1.12 0.0.0.0 ace-priority 3640
permit ip any 192.168.1.15 0.0.0.0 ace-priority 3660
permit ip any 192.168.0.0 0.0.0.255 ace-priority 3680
permit ip any 172.16.44.248 0.0.0.7 ace-priority 3700
permit ip any 192.168.254.0 0.0.0.255 ace-priority 3720
permit ip any 192.168.2.0 0.0.0.255 ace-priority 3740
permit ip any 192.168.3.0 0.0.0.255 ace-priority 3760
permit ip any 192.168.4.0 0.0.0.255 ace-priority 3780
permit ip any 192.168.5.0 0.0.0.255 ace-priority 3800
deny ip any 192.168.0.0 0.0.255.255 ace-priority 3820
deny ip any 172.16.0.0 0.0.31.255 ace-priority 3840
deny ip any 10.0.0.0 0.255.255.255 ace-priority 3860
exit
ip access-list extended MANAGEMENT
permit ip any 192.168.1.12 0.0.0.0 ace-priority 40
permit ip any 192.168.1.15 0.0.0.0 ace-priority 60
permit ip any 192.168.44.0 0.0.0.255 ace-priority 80
permit ip any 192.168.1.0 0.0.0.255 ace-priority 100
permit ip any 172.16.44.248 0.0.0.7 ace-priority 120
permit ip any 192.168.254.0 0.0.0.255 ace-priority 140
permit ip any 10.0.0.0 0.0.0.255 ace-priority 160
deny ip any 192.168.0.0 0.0.255.255 ace-priority 180
deny ip any 172.16.0.0 0.0.31.255 ace-priority 200
deny ip any 10.0.0.0 0.255.255.255 ace-priority 220
exit
ip access-list extended TELEPHONIE
permit ip any 192.168.1.14 0.0.0.0 ace-priority 180
permit ip any 192.168.1.12 0.0.0.0 ace-priority 200
permit ip any 192.168.1.15 0.0.0.0 ace-priority 220
permit ip any 10.1.44.0 0.0.0.255 ace-priority 240
permit ip any 172.16.44.248 0.0.0.7 ace-priority 260
permit ip any 192.168.254.0 0.0.0.255 ace-priority 280
permit ip any 10.0.0.0 0.0.0.255 ace-priority 290
deny ip any 192.168.0.0 0.0.255.255 ace-priority 300
deny ip any 10.0.0.0 0.255.255.255 ace-priority 340
exit
hostname SW3-RG-1
no passwords complexity enable
ip ssh server
snmp-server contact SI
no ip http server
clock timezone CET +1
clock summer-time CEST recurring last sun oct 02:00 last sun mar 03:00
ip domain name imie
ip name-server 192.168.1.15 192.168.1.12
interface vlan 1
shutdown
interface vlan 10
name USERS-PRODUCTION
ip address 172.16.44.126 255.255.255.128
service-acl input USERS-PRODUCTION default-action permit-any
interface vlan 11
name USERS-INVITES
ip address 172.16.44.190 255.255.255.192
service-acl input USERS-INVITES default-action permit-any
interface vlan 12
name USERS-SI
ip address 172.16.44.254 255.255.255.248
service-acl input USERS-SI default-action permit-any
interface vlan 13
name USERS-FORMATION
ip address 172.31.255.254 255.255.0.0
service-acl input USERS-FORMATION default-action permit-any
interface vlan 100
name VIDEO-PROJ
ip address 10.1.1.254 255.255.255.0
service-acl input VIDEO-PROJ default-action permit-any
interface vlan 101
name JSEC
ip address 10.1.2.254 255.255.255.0
service-acl input JSEC default-action permit-any
interface vlan 102
name AFFICHAGE-DYN
ip address 10.1.3.254 255.255.255.0
service-acl input AFFICHAGE-DYN default-action permit-any
interface vlan 103
name BAC-A-SABLE
ip address 10.1.4.254 255.255.255.0
service-acl input BAC-A-SABLE default-action permit-any
interface vlan 200
name MANAGEMENT
ip address 192.168.44.254 255.255.255.0
service-acl input MANAGEMENT default-action permit-any
interface vlan 201
name TELEPHONIE
ip address 10.1.44.254 255.255.255.0
service-acl input TELEPHONIE default-action permit-any
interface vlan 254
name INTERCO
ip address 192.168.254.1 255.255.255.0
interface vlan 1000
name SRV-SERVICES
ip address 192.168.0.254 255.255.255.0
service-acl input SRV-SERVICES default-action permit-any
interface vlan 1001
name SRV-PRODUCTION
ip address 192.168.1.254 255.255.255.0
service-acl input SRV-PRODUCTION default-action permit-any
interface vlan 1002
name SRV-FORMATION
ip address 10.1.0.254 255.255.255.0
service-acl input SRV-FORMATION default-action permit-any
interface gigabitethernet1
description "Prise 0013A4 - Salle 110"
spanning-tree guard root
spanning-tree bpduguard enable
switchport mode access
switchport access vlan 13
interface gigabitethernet2
description "Prise 0013A5 - Salle 110"
interface gigabitethernet3
description "Prise 0013A6 - Salle 110"
interface gigabitethernet4
description "Prise 0013A7 - Salle 110"
interface gigabitethernet5
description "Prise 0013A8 - Salle 110"
interface gigabitethernet6
description Salle_107
interface gigabitethernet7
description "Serveur HV02"
switchport access vlan 1001
interface gigabitethernet8
interface gigabitethernet9
interface gigabitethernet10
interface gigabitethernet11
description "Prise 00-3A1 - Salle 104"
interface gigabitethernet12
description "Prise 00-29B3 - Salle 102"
interface gigabitethernet13
description "Salle 106"
interface gigabitethernet14
interface gigabitethernet15
interface gigabitethernet16
interface gigabitethernet17
interface gigabitethernet18
interface gigabitethernet19
interface gigabitethernet20
switchport access vlan 12
interface gigabitethernet21
interface gigabitethernet22
description "LIAISON NANTES HV3 IMIE SERVICES"
switchport access vlan 1000
interface gigabitethernet23
description LIAISON-FORMATION-NANTES-HV1
switchport access vlan 1002
interface gigabitethernet24
description "SRV FORMATION"
interface gigabitethernet25
interface gigabitethernet26
interface gigabitethernet27
interface gigabitethernet28
interface gigabitethernet29
interface gigabitethernet30
interface gigabitethernet31
description Salle_105
interface gigabitethernet32
interface gigabitethernet33
interface gigabitethernet34
description "Salle 108 - RDE0.017A1"
interface gigabitethernet35
interface gigabitethernet36
interface gigabitethernet37
description "Salle 104 - 003E1"
interface gigabitethernet38
description "Salle 104 - RDE0.03A2"
interface gigabitethernet39
description "Salle 104 - RDE0.03A3"
interface gigabitethernet40
description "Salle 104 - RDE0.03B1"
interface gigabitethernet41
description "Port 003c1 - Salle 104"
interface gigabitethernet42
description "Port 003B2 - Salle 104"
interface gigabitethernet43
interface gigabitethernet44
interface gigabitethernet45
interface gigabitethernet46
interface gigabitethernet47
description LIAISON-PRODUCTION-NANTES-HV3
switchport trunk allowed vlan add 10-13,100-103,200-201,254,1000,1002
switchport trunk native vlan 1001
interface gigabitethernet48
description "Liaison NANTES-HV2"
interface gigabitethernet49
description IT'PBX
switchport access vlan 201
interface gigabitethernet50
description IT'GATEWAY
switchport access vlan 254
interface gigabitethernet51
description SW2-RG-5
switchport trunk allowed vlan add 10-13,100-103,200-201,254,1000-1002
interface gigabitethernet52
description SW2-RG-2
exit
ip igmp snooping
ip igmp snooping vlan 1
ip igmp snooping vlan 1 immediate-leave
ip igmp snooping vlan 10
ip igmp snooping vlan 10 immediate-leave
ip igmp snooping vlan 11
ip igmp snooping vlan 11 immediate-leave
ip igmp snooping vlan 12
ip igmp snooping vlan 12 immediate-leave
ip igmp snooping vlan 13
ip igmp snooping vlan 13 immediate-leave
ip igmp snooping vlan 100
ip igmp snooping vlan 100 immediate-leave
ip igmp snooping vlan 101
ip igmp snooping vlan 101 immediate-leave
ip igmp snooping vlan 102
ip igmp snooping vlan 102 immediate-leave
ip igmp snooping vlan 103
ip igmp snooping vlan 103 immediate-leave
ip igmp snooping vlan 200
ip igmp snooping vlan 200 immediate-leave
ip igmp snooping vlan 201
ip igmp snooping vlan 201 immediate-leave
ip igmp snooping vlan 254
ip igmp snooping vlan 254 immediate-leave
ip igmp snooping vlan 1000
ip igmp snooping vlan 1000 immediate-leave
ip igmp snooping vlan 1001
ip igmp snooping vlan 1001 immediate-leave
ip igmp snooping vlan 1002
ip igmp snooping vlan 1002 immediate-leave
ip default-gateway 192.168.254.254
What is the subnet of the remote site? I suspect your ACLs are blocking the return traffic.
cheers,
Seb.
the remote site is 192.168.3.0/24, passing through 192.168.254.1 (vlan 254) which have not acl input.
In the TELEPHONIE ACL, we have correctly added 192.168.3.0 0.0.0.0255 as authorized network.
If i modify 192.168.3.0/24 by 1.1.1.0/24, all is working fine..
So if you change the subnet at the remote site to 1.1.1.0/24 the traffic passes in both directions through the SG300, without needing to change the ACLs?
Yes, exactly
If you inserted the following to the TELEPHONE ACL:
permit ip any 192.168.3.0 0.0.0.255 ace-priority 291
...does it work?
The 1.1.1.0/24 traffic is allowed through because of the default-action permit statement you have on your ACLs.
Not at all
Just to clarify, you are inserting the permit 192.168.3.0 0.0.0.255 above the following deny:
To clarify, I have tested to add only permit ip any any without any success too
