L2 Trunk question
knuckleheadbob
working with 3845 w 2 nm-16esw-1g network modules having issues with connectivity across the trunks i have also duplicated the issue with gns3 so i must be missing something simple, if anyone could shed some light on what im missing. for reference here is my gns3 config just trying to do a simple ping from R1-R2 / R2-R1 on any vlan
R1
version 12.4
hostname R1
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip icmp rate-limit unreachable
ip cef
no ip domain lookup
vtp domain cisco
vtp mode transparent
archive
log config
hidekeys
vlan 10,50-51,100,200
ip tcp synwait-time 5
interface FastEthernet0/0
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet0/1
no ip address
shutdown
duplex auto
speed auto
interface FastEthernet1/0
switchport trunk native vlan 10
switchport mode trunk
duplex full
speed 100
interface FastEthernet1/1
interface FastEthernet1/2
interface FastEthernet1/3
interface FastEthernet1/4
interface FastEthernet1/5
interface FastEthernet1/6
interface FastEthernet1/7
interface FastEthernet1/8
interface FastEthernet1/9
interface FastEthernet1/10
interface FastEthernet1/11
interface FastEthernet1/12
interface FastEthernet1/13
interface FastEthernet1/14
interface FastEthernet1/15
interface FastEthernet2/0
interface FastEthernet2/1
interface FastEthernet2/2
interface FastEthernet2/3
interface FastEthernet2/4
interface FastEthernet2/5
interface FastEthernet2/6
interface FastEthernet2/7
interface FastEthernet2/8
interface FastEthernet2/9
interface FastEthernet2/10
interface FastEthernet2/11
interface FastEthernet2/12
interface FastEthernet2/13
interface FastEthernet2/14
interface FastEthernet2/15
interface Vlan1
no ip address
interface Vlan10
ip address 172.16.10.1 255.255.255.0
interface Vlan50
ip address 172.16.50.1 255.255.255.0
interface Vlan51
ip address 172.16.51.1 255.255.255.0
interface Vlan100
ip address 172.16.100.1 255.255.255.0
interface Vlan200
ip address 172.16.200.1 255.255.255.0
ip forward-protocol nd
no ip http server
no ip http secure-server
no cdp log mismatch duplex
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R2
ersion 12.4
hostname R2
boot-start-marker
boot-end-marker
no aaa new-model
memory-size iomem 5
no ip routing
no ip cef
no ip domain lookup
vtp domain cisco
archive
log config
hidekeys
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
no ip address
no ip route-cache
shutdown
duplex auto
speed auto
duplex full
speed 100
interface Vlan1
no ip address
no ip route-cache
interface Vlan10
ip address 172.16.10.2 255.255.255.0
no ip route-cache
interface Vlan50
ip address 172.16.50.2 255.255.255.0
no ip route-cache
interface Vlan51
ip address 172.16.51.2 255.255.255.0
no ip route-cache
interface Vlan100
ip address 172.16.100.2 255.255.255.0
no ip route-cache
interface Vlan200
ip address 172.16.200.2 255.255.255.0
no ip route-cache
no ip http server
control-plane
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
exec-timeout 0 0
privilege level 15
logging synchronous
line vty 0 4
login
end
R1 - info
R1#sh int fa1/0 trunk
Port Mode Encapsulation Status Native vlan
Fa1/0 on 802.1q trunking 10
Port Vlans allowed on trunk
Fa1/0 1-4094
Port Vlans allowed and active in management domain
Fa1/0 1,10,50-51,100,200
Port Vlans in spanning tree forwarding state and not pruned
R1#sh int fa1/0 switchport
Switchport: Enabled
Administrative Mode: trunk
Operational Mode: trunk
Administrative Trunking Encapsulation: dot1q
Operational Trunking Encapsulation: dot1q
Negotiation of Trunking: Disabled
Access Mode VLAN: 0 ((Inactive))
Trunking Native Mode VLAN: 10 (VLAN0010)
Trunking VLANs Enabled: ALL
Trunking VLANs Active: 1,10,50-51,100,200
Protected: false
Priority for untagged frames: 0
Override vlan tag priority: FALSE
Voice VLAN: none
Appliance trust: none
R1#sh vtp stat
VTP Version                     : 2
Configuration Revision          : 0
Maximum VLANs supported locally : 68
Number of existing VLANs        : 10
VTP Operating Mode              : Transparent
VTP Domain Name                 : cisco
VTP Pruning Mode                : Disabled
VTP V2 Mode                     : Disabled
VTP Traps Generation            : Disabled
MD5 digest                      : 0xB5 0x5D 0xF1 0x5A 0x2D 0xAF 0x18 0x91
Configuration last modified by 0.0.0.0 at 3-1-02 00:24:01
R2 - info
R2#sh int fa1/0 trunk
Fa1/0 1-4094
2#sh int fa1/0 switchport
Switchport: Enabled
Protected: false
Voice VLAN: none
R2#sh vtp stat
VTP Version                     : 2
Maximum VLANs supported locally : 36
Configuration last modified by 0.0.0.0 at 3-1-02 00:01:49
vtp debug info
VTP PRUNING INFO: chg trunk Fa1/0 vlan 1 SPT st to 1 (no pruning)
VTP PRUNING INFO: domain cisco vlan 10 chg local assoc to 1
VTP PRUNING INFO: chg trunk Fa1/0 vlan 10 SPT st to 1 (no pruning)
VTP PRUNING INFO: domain cisco vlan 50 chg local assoc to 1
VTP PRUNING INFO: chg trunk Fa1/0 vlan 50 SPT st to 1 (no pruning)
VTP PRUNING INFO: domain cisco vlan 51 chg local assoc to 1
VTP PRUNING INFO: chg trunk Fa1/0 vlan 51 SPT st to 1 (no pruning)
VTP PRUNING INFO: domain cisco vlan 100 chg local assoc to 1
VTP PRUNING INFO: chg trunk Fa1/0 vlan 100 SPT st to 1 (no pruning)
VTP PRUNING INFO: domain cisco vlan 200 chg local assoc to 1
VTP PRUNING INFO: chg trunk Fa1/0 vlan 200 SPT st to 1 (no pruning)
Could you share the output of "sh int status | i Fa1/0", "sh int fa1/0" and "sh spanning-tree"from both devices?
HTH,
Meheretab
HTH,
Meheretab
thanks for the reply here is the output for both interfaces and spanning-tree, i sure appreciate any insight you can shed on this
R1#sh int status | i Fa1/0
Fa1/0 connected trunk full 100 10/100BaseTX
R1#sh int fa1/0
FastEthernet1/0 is up, line protocol is up
Hardware is Fast Ethernet, address is c402.01bd.f100 (bia c402.01bd.f100)
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
Keepalive set (10 sec)
Full-duplex, 100Mb/s
Last input 00:00:01, output never, output hang never
Queueing strategy: fifo
Output queue: 0/40 (size/max)
0 packets input, 0 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 packets output, 0 bytes, 0 underruns
0 output errors, 0 collisions, 4 interface resets
0 unknown protocol drops
0 lost carrier, 0 no carrier
R1#sh spanning-tree
VLAN1 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0000
Configured hello time 2, max age 20, forward delay 15
Current root has priority 32768, address c201.0191.0000
Root port is 41 (FastEthernet1/0), cost of root path is 19
Topology change flag not set, detected flag not set
Number of topology changes 1 last change occurred 00:02:50 ago
Times: hold 1, topology change 35, notification 2
hello 2, max age 20, forward delay 15
Timers: hello 0, topology change 0, notification 0, aging 300
Port 41 (FastEthernet1/0) of VLAN1 is forwarding
Port path cost 19, Port priority 128, Port Identifier 128.41.
Designated root has priority 32768, address c201.0191.0000
Designated bridge has priority 32768, address c201.0191.0000
Designated port id is 128.41, designated path cost 0
Timers: message age 1, forward delay 0, hold 0
Number of transitions to forwarding state: 1
BPDU: sent 11, received 244
VLAN10 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0001
Current root has priority 32768, address c201.0191.0001
Number of topology changes 1 last change occurred 00:02:52 ago
Port 41 (FastEthernet1/0) of VLAN10 is forwarding
Designated root has priority 32768, address c201.0191.0001
Designated bridge has priority 32768, address c201.0191.0001
BPDU: sent 6, received 249
VLAN50 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0002
Current root has priority 32768, address c201.0191.0002
Number of topology changes 1 last change occurred 00:03:02 ago
Port 41 (FastEthernet1/0) of VLAN50 is forwarding
Designated root has priority 32768, address c201.0191.0002
Designated bridge has priority 32768, address c201.0191.0002
Timers: message age 2, forward delay 0, hold 0
BPDU: sent 6, received 253
VLAN51 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0003
Current root has priority 32768, address c201.0191.0003
Number of topology changes 1 last change occurred 00:03:10 ago
Port 41 (FastEthernet1/0) of VLAN51 is forwarding
Designated root has priority 32768, address c201.0191.0003
Designated bridge has priority 32768, address c201.0191.0003
BPDU: sent 6, received 254
VLAN100 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0004
Current root has priority 32768, address c201.0191.0004
Number of topology changes 1 last change occurred 00:03:13 ago
Port 41 (FastEthernet1/0) of VLAN100 is forwarding
Designated root has priority 32768, address c201.0191.0004
Designated bridge has priority 32768, address c201.0191.0004
BPDU: sent 5, received 255
VLAN200 is executing the ieee compatible Spanning Tree protocol
Bridge Identifier has priority 32768, address c402.01bd.0005
Current root has priority 32768, address c201.0191.0005
Number of topology changes 1 last change occurred 00:03:15 ago
Port 41 (FastEthernet1/0) of VLAN200 is forwarding
Designated root has priority 32768, address c201.0191.0005
Designated bridge has priority 32768, address c201.0191.0005
BPDU: sent 5, received 256
R1#
R2#sh int status | i Fa1/0
R2#sh int fa1/0
Hardware is Fast Ethernet, address is c201.0191.f100 (bia c201.0191.f100)
Last input 00:00:34, output never, output hang never
0 output errors, 0 collisions, 6 interface resets
R2#sh spanning-tree
Bridge Identifier has priority 32768, address c201.0191.0000
We are the root of the spanning tree
Number of topology changes 1 last change occurred 00:06:01 ago
from FastEthernet1/0
Timers: hello 1, topology change 0, notification 0, aging 300
Timers: message age 0, forward delay 0, hold 0
BPDU: sent 354, received 2
Bridge Identifier has priority 32768, address c201.0191.0001
BPDU: sent 179, received 2
Bridge Identifier has priority 32768, address c201.0191.0002
Number of topology changes 1 last change occurred 00:06:05 ago
BPDU: sent 191, received 2
Bridge Identifier has priority 32768, address c201.0191.0003
Number of topology changes 1 last change occurred 00:06:28 ago
BPDU: sent 192, received 2
Bridge Identifier has priority 32768, address c201.0191.0004
Number of topology changes 1 last change occurred 00:06:30 ago
BPDU: sent 193, received 2
Bridge Identifier has priority 32768, address c201.0191.0005
Number of topology changes 1 last change occurred 00:06:32 ago
BPDU: sent 194, received 2
R2#
just a bit more info here are the arp results from a simple ping on vlan10 from R2 to R1
R1# sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  172.16.10.1             -   c402.01bd.0000  ARPA   Vlan10
Internet  172.16.10.2             0   c201.0191.0000  ARPA   Vlan10
Internet  172.16.50.1             -   c402.01bd.0000  ARPA   Vlan50
Internet  172.16.51.1             -   c402.01bd.0000  ARPA   Vlan51
Internet  172.16.100.1            -   c402.01bd.0000  ARPA   Vlan100
Internet  172.16.200.1            -   c402.01bd.0000  ARPA   Vlan200
R1#
R2#sh arp
Internet 172.16.10.1 0 Incomplete ARPA
Internet 172.16.10.2 - c201.0191.0000 ARPA Vlan10
Internet 172.16.50.2 - c201.0191.0000 ARPA Vlan50
Internet 172.16.51.2 - c201.0191.0000 ARPA Vlan51
Internet 172.16.100.2 - c201.0191.0000 ARPA Vlan100
Internet 172.16.200.2 - c201.0191.0000 ARPA Vlan200
R2#
