Cisco SG350 issue
dtriminio
Hello Community,
Currently I have problems with Cisco SG350 model, in these I configure its ports in Access mode with a specific vlan, but after they are turned off or restart by electrical issues, all its ports lose configuration and are automatically put in trunk mode with all the vlan declared in the switch, this only happens to me with this specific model, does anyone know how I can solve so that the configuration is not changed when restarting?
we try updating the firmware but the issue persists
Active-image: flash://system/images/image_tesla_hybrid_2.4.0.94.bin
Version: 2.4.0.94
MD5 Digest: 6f5be217100f34929986f2e93dd2d5e9
Date: 31-May-2018
Time: 02:39:58
Inactive-image: flash://system/images/image1.bin
Version: 2.3.5.63
MD5 Digest: 5881484e04bcdcc17c32872445e3ab8d
Date: 20-Aug-2017
Time: 19:04:55
Jaderson Pessoa
Guy, i think that you has a flash card issue. So you have somes alternative for resolve it.
1: change sd card flash
2: Change boot config setings to run through tftp / usb
save your startup-config file on usb or tftp server and insert this comands;
boot config usb:/xxxxxxx.bin
or
boot config tftp://ip address/filename
Thats it.
Jaderson Pessoa
*** Rate All Helpful Responses ***
