Cisco SG350x - Data and Voice vlan issue
Dave_22
Hello everyone,
I am stuck with the scenario below and would be grateful if anyone could provide me with a solution:
The company am working with has 2 departments: X Corporation and Y Services
Y Services has been newly created and works in parallel with X Corporation
We currently have Cisco IP Phones which will connect to the the Cisco SG350x and behind each phone we will have a laptop
Voice vlan50 needs to communicate via trunk link to VOIP router within X Corporation
Vlan 10 and 20 in turn need to communicate with the firewall to lease IP addresses from the latter
Following test configuration applied (only for Vlan 10 and 50) but still KO:
Port 1: -> Only Phone works but laptop is unable to receive an IP address from the firewall
interface GigabitEthernet1/0/1
description Test_Admin_Zone
ip dhcp relay enable
switchport mode trunk
switchport trunk native vlan 10
no macro auto smartport
Trunk ports:
Trunk data
interface GigabitEthernet1/0/47
switchport trunk allowed vlan remove 2-9,11-4094
Trunk - Voice
interface GigabitEthernet1/0/48
switchport trunk allowed vlan remove 2-49,51-4094
Please Help!!!!!!!!!!!!
Check a few more things:
1. Are you working with the Cisco IP Phone? If Yes, then must enable the CDP protocol?
2. If you are working on another Vendor phone then you must enable LLDP Protocol on global configuration mode.
Now, I am looking at your port configuration which is not correct:
interface GigabitEthernet1/0/27
switchport trunk allowed vlan 50
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
9 Replies 9
Deepak Kumar
Configure your switch like as:
voice vlan id 50
interface fastethernet11
spanning-tree portfast
switchport trunk native VLAN 10
switchport trunk allowed VLAN add 10,50
Deepak Kumar,
Dear Deepak,
Kindly note that the suggested configurations do not work in my case
Whereas the below configuration is working but I have to statically configure the IP address on test laptopn in vlan10:
voice vlan id 50
switchport mode general
switchport general allowed vlan add 10 tagged
switchport general allowed vlan add 1,50 untagged
#### New trunk Port for Voice ####
spanning-tree link-type point-to-point
#### Trunk for Data in Vlan 10 ####
switchport trunk allowed vlan remove 2-9,10-4094
Do you have an idea why I do not receive an IP automatically through the DHCP Server?
Thanking you in advance
Deepak Kumar,
Dear Deepak,
Thank you so much
The configurations are working and laptop able to pull IP Address from the firewall
Warm Regards
Hello
Do you obtain dhcp allocation if you just attach the laptop to the switchport without the voip device.
Where is your dhcp server! What device is performing inter- vlan routing?
You  may need to apply a dhcp relay on your L3 vlan interfaces if your dhcp server resides off you lan!
Kind Regards
Paul
try and change the access port configuration to:
switchport trunk allowed vlan add 50
Dear Georg,
Kindly read through my response to Deepak
If you could provide your help on the DHCP issue
Could you please answer the above questions, it will assist in the troubleshooting of your issue.
Also on a side note, I notice you have spanning-tree portfast suggested to be applied to your trunks port, if you do require a trunk port to go straight into a forwarding state without going through the stp process then in the current form it will not work, on a trunk you need to apply spanning-tree portfast trunk  but this isn't recommended to do this unless your certain that port isn't capable of causing any issues like introducing a loop, trunk portfast is usually applied to trunkports interconnecting servers that support trunking themselves and have more than one network card installed
Kind Regards
Paul
Hello Paul,
I did not obtain an IP Address when the Cisco IP Phone is bypassed (with or without the IP Phone, issue remained the same)
My dhcp server's job is being performed by the connected interfaces of the firewall
Working configurations are:
Vlan 10
Vlan 20
description Test_User_Zone
switchport trunk native vlan 20
switchport trunk allowed vlan remove 2-19,21-4094
With above configurations, PCs in both vlan 10 & 20 were able to fetch IP Address from the firewall with IP Phones working correctly and fetching IP Address from the VOIP Router.
Thank you for the trunk port configurations
All working good now :)
