Cisco SG550X switch DHCP Snooping & DF (Do not fragment) Issue
Yasmeen
Hi Team
         we have one CIsco SG550X switch, when i configured the DHCP Snooping on it. The DF (Fragment is set to as DF =1)
        In Wireshark Capture its showing as Do NOt Fragment.
I have one setup as follows
DHCP Snooping Enabling in SG550X switch
AP ----> CIsco SG 550 X Switch  ----> TFTP Machine
set DF =0 ----> changed as DF = 1 -----> Same DF = 1
AP (Access Point) Image UPgarde is not Successful
DHCP Snooping Disabling in SG550X switch
set DF =0 ----> changed as DF = 0 -----> Same DF = 0
DF bits sets as 65454
AP (Access Point) Image UPgarde is Successful
I want to enable the DHCP Snooping in cisco SG5550X switch at the same time my Access point Image Upgrade also need to be fine with DF = 0 (65454 bits)
Even though DHCP snooping is disabled, DF bit is set to 1 only..
May be I'm thinking there might be some packet loss when DHCP snooping is enabled. Because of that while doing re-fragmentation at that time it fails
How do i enable both options ?
What configuration needs to be done ?
What are all things happened when DHCP Snooping Enbaled in switch ?
what i need to configure ?
Pls help me to troubleshoot in Cisco Switch
Thanks in Advance,
Yasmeen Shaul Hameed.
I don't think there is an option on the SG550x that let's you set the DF bit at all. DHCP snooping is, in theory, completely unrelated.
Which firmware version are you running on the switch > Make sure it is the latest, release 2.5.5.47 (attached in case you don't have it).
Yasmeen
Hi georg
                  I have the same Image in my switch.
#show version
Active-image: flash://system/images/image_tesla_hybrid_2.5.5.47_release_cisco_signed.bin
Version: 2.5.5.47
MD5 Digest: ff7132e875fd9ac0699a4b7bf04087c4
Date: 06-May-2020
Time: 17:32:16
My Issue is,
my Access point sent the request to TFTP via cisco Switch
Access Point -----> CIsco SG550X switch ----> TFTP
DF = 0 -------> Changed as DF = 1 ----->
Automatically my Fragment value as = 1
In switch it's showing as Do not fragment
I want to transfer the MTU value as 65454
not with default MTU size - 512, 1024
Why automatically my DF bit changed as 1
when i set the value DF = 0 in Access point
Pls let me know the reason for from AP DF = 0 to SG550x switch DF = 1 changing ?
Thanks in Advance,
