Cisco Simulator
saitkenhead
Community Member
Looking for top notch network simulator that will support 6509's, 2950's, 2940's 3750's and 3560's. Any recomendations would be greatly appreciated.
Thanks in advance.
Boson Netsim is good, I used that during my CCNA, served me well.
Pavel Bykov
Level 10
Level 10
Those are switches, those are very complex to simulate, so you'll end up with some FLASH SIMULATOR that simulates command line, not the switch.
The best emulator ever is Dynamips:
http://www.ipflow.utc.fr/index.php/Cisco_7200_Simulator
But it supports only routers, not switches.
Still, you load REAL IOS (it's HW emulation), so it's all very realistic.
Hope this helps
Thanks! was hoping for a diff answer but them the breaks. What would you say is the best emulater for CCNA cert then?
