Cisco SM-X Layer 2/3 EtherSwitch Service Module (ESM)
albazi.aq
when i install the SM-X Ethernet switch service module with 16 port there is two extra port in the number of the interface and the GigabitEthernet0/17 and GigabitEthernet0/18.
can someone told me what are these interfaces.
thanks
Reza Sharifi
I think GigabitEthernet0/17 and GigabitEthernet0/18 are the uplinks to the router.
you are correct but i do not know why the GigabitEthernet0/17 cannot be routed port but the GigabitEthernet0/18 can.
Did not know that and not sure exactly why that is the case.
maybe Cisco wants to keep the function separate per port.
shinji7800
I would also like to understand what are the differences between these ports
I don't find clearly the purpose of each
thanks
