Cisco small Switches
I need to purchase new small Cisco Switches with 16 ports
Features I require inside these switches are:
1- 802.1x
2- mac-based port-security
Can anyone please recommend me which cisco switch series I should order ?
Philip D'Ath
The smallest are 24 port, and you could consider the 2960-X series.  Note you need a RADIUS server to use 802.1x.
https://www.cisco.com/c/en/us/products/switches/catalyst-2960-x-series-switches/index.html
thanks Philip
May I know, do these 2960-X series switches support for TrustSec / SGT ?
in addition to Philip's post, and depending on your budget, you also might want to consider something like the Meraki MS120-24, which is about one third of the price of the 2960-X...
https://meraki.cisco.com/products/switches/ms120-24
