SG300-10SFP transceiver compatibility
colskinet
Hi all,
I have an SG300-10SFP.  Can someone confirm if a 10G SFP+ module will work in this switch?  I'm unable to ascertain if they will run at the lower speed of 1G.
The transceiver in question is an Intel FTLX8571D3BCVIT1.
I've plugged one in and I'm not getting a link light on the switch.
I appreciate I am plugging an SFP+ module into an SFP port!
Thanks in advance.
it won't work. SFP+ does not support 1Gigabit speeds.
Check out the document below, it has pretty useful information on the differences between the various SFPs...
http://www.sopto.com/learningcenter_learningcenter_71/the_difference_of_sfp_plus,_sfp_and_xfp.shtml
Hi Georg,
Thanks for the reply and confirming. I was just a bit confused as when I looked on the switch and the optic details I could see it displaying the temperature etc so wasn’t too sure what was going on!
