Cisco Smart Install Protocol Vunerability
georgehewittuk1
Hi All,
I've detected that one of our devices is affected by a vunerability [https://tools.cisco.com/security/center/content/CiscoSecurityAdvisory/cisco-sa-20170214-smi] whereby Smart Install client is exploted. Our code version does not allow us to do a 'no vstack' to disable the feature.
Other than the ACL workaround how can I verify what future code versions offer the ability to disable the feature if we were to upgrade? To conclude I'm looking on how one would check for a future code version that allows us to turn off or the Smart install is disabled!
Many Thanks
George
ok thats odd they dont allow to disable the feature , i can confirm that in later version you can disable it im running 3.8.6 IOS-XE on 45s
and on my 3650/38s were running 3.6.7b and we can disable it on that too
You may be stuck with the ACL workaround for your current image
What platform are you on ?
xxxxxx#sh vstack config | i Disabled
Oper Mode: Disabled
xxxxxx#sh ver | i SPA.03.08.06
System image file is "bootflash:cat4500es8-universalk9.SPA.03.08.06.E.152-4.E6.bin"
5 Replies 5
Mark Malone
You would need to check the command output for that specific IOS version on the Cisco website or post the version your going to use and see if someone is running it already and can confirm ,eacxh IOS has a linked command output guide by alphabetical order , you could confirm there if the command is present in that code to disable
out of interest which version are you on as we disabled this on all our IOS-XE devices last year without issue
also did you check its not already disabled by default in show run all | i vstack
EDIT : if you cant turn it off it cant be on usually , are you sure this specific version is effected ?
Thanks for your reply.
Code version -  03.08.02.E
It is defintley enabled unforuntaely.
#show vstack config Role: Client (SmartInstall enabled)
Even if we knew when the command was added that would be of use!
Oper Mode: Disabled
That is very helpful knowing we can do it after this code release. Going to look at upgrading
Upgrade the stack. The command "no vstack" is available in later releases.
