CISCO SMB NETWORK PROJECT
I-TECH
Good Afternoon All-
We are working on a new networking project, the client has very limited funding resources.
REQUIREMENTS:
Separate VLANS for VOICE | DATA | SECURITY SYSTEMS | WIRELESS.
But, Need to Maintain Connections to Domain Resources for DNS and DHCP Server Access connected on SW1.
CURRENT HARDWARE:
FW1 | CISCO ASA5520 | Routing Mode
SW1 | CISCO SG300-28 | L3 Routing Mode | DOMAIN SERVERS | MANAGED
SW2 | CISCO SG300-28 | L3 Routing Mode | SECURITY SYSTEMS & WIRELESS | MANAGED
SW3 | CISCO SG300-28 | PoE | VOICE PHONES | UN-MANAGED
SW1 -> SW3 | PORTS: 24 -> 28 | TRUNKS
VLANS:
VLAN 1 DEFAULT | x.x.1.0 | ALL PORTS | UN-TAGGED
VLAN 10 DATA    | x.x.10.0 |ALL PORTS | TAGGED
VLAN 20 VOICE   | x.x.20.0 | ALL PORTS | TAGGED
VLAN 30 WIRELESS | x.x.30.0 | ALL PORTS | TAGGED
VLAN 40 SECURITY | x.x.40.0 | ALL PORTS | TAGGED
All Devices are configured with their respective VLAN IP Addresses.
All Workstations are connected to the network via the Cisco IP Phones...
How can we configure VOICE to work and still get Domain Resource Access?
Thanks...
2 Accepted Solutions
NinjaPirate
(config)#voice vlan id 20
(config)#voice vlan state auto-enabled
(config)#interface range fa1-23
(config-if-range)#switchport trunk native vlan 10
(config-if-range)#switchport trunk allowed vlan add 20
A good way to do it is to understanding the setup and giving the right direction.
Your information not given detailed which IP address going to be where? since its L3 where is the Gateways and SVI configured?
The main issue is separating the traffic on SW1 and SW2 BUT Allowing VOICE TRAFFIC to SW3 which is a Cisco Non-Managed Switch.
BB -A couple of ways to do it is - Segment the network or handover to FW as gateway make FW rules.
BB
5 Replies 5
balaji.bandi
Draw a simple network diagram to understand the network Flow. So you can implement ACL / FW Rules to meet your requirements.
BB
@bb
Thanks for your reply...
However, this response is not detailed enough...
ACL's are already set on the ASA for the VLANS.
The Cisco IP Phones Live Here!
Workstations's are connected to the IP Phone PC Port #2
Workstations will need access to Domain Resources for DNS, DHCP, Etc...
Awaiting Responses...
Thanks Again.
BB
NinjaPirate
@NinjaPirate
Thank you for responding...
Which Switch should this apply to:
SW1 | MANAGED | DOMAIN RESOURCES
SW2 | MANAGED |DOMAIN RESOURCES
SW3 PoE UN-MANAGED | IP Phones Live Here!
Thanks...
