Cisco StackWise Virtual for 9407
sejelmohajj
Level 3
Level 3
Can i use line cards Ports to configure DAD Link between Stack Switches, as i am using my SUP 40Gig's ports for VSL.
3 Accepted Solutions
Reza Sharifi
yes, you can use a port from a line card.
My apologies. It appears that only the sup ports support DAD. Have a look at table-1 in this link:
https://www.cisco.com/c/dam/en/us/products/collateral/switches/catalyst-9000/nb-06-cat-9k-stack-wp-cte-en.pdf
Correct. 10Gig ports are fine for DAD and Virtual links. You really don't need 40Gig specialty for DAD.
So, you will be just fine with 10Gig ports.
5 Replies 5
Reza Sharifi
The Port-Channel is not coming up..
jed-bt-dc-sw9407-i#sh run | s stackwise-virtual
stackwise-virtual
domain 1
dual-active detection pagp trust channel-group 1
stackwise-virtual link 1
interface TenGigabitEthernet1/2/0/24
channel-protocol pagp
channel-group 1 mode desirable
interface TenGigabitEthernet2/2/0/24
interface Port-channel1
end
jed-bt-dc-sw9407-i#show stackwise-virtual dual-active-detection pagp
Pagp dual-active detection enabled: Yes
In dual-active recovery mode: No
Channel group 1
Dual-Active Partner Partner Partner
Port Detect Capable Name Port Version
Te1/2/0/24 Yes None None 1.1
Te2/2/0/24 No None None N/A
You are right, So it means , if i want to configure VSL and DAD I have to use only 10 Gig Ports whereas if i use 40 Gig Ports i can't configure DAD.
