Switch management vlan IP unreachable
MrBeginner
Dear All,
let me know why my switch management IP cannot ping from anywhere.MY pc can ping to router and vlan interfaces.router can ping vlan interface itself. router cannot ping to  switch management IP. Router Model is c892 and switches model is ws-c2960+24tc-s (LanLite).
Switch have have 4 vlan and carry traffic with trunk to router and router have 4 vlan interfaces.(i didn't use router on the stick .
let me know which IP should i need to set as ip default-gateway?
i set management interface ip as default gateway in switches but cannot solve.
PLease see below config and help me to solve.
Router config:
vlan 20
vlan 21
vlan 22
vlan 23
vlan 77
interface Vlan20
description management vlan
ip address 1.1.8.1 255.255.255.0
interface Vlan21
ip address 1.1.7.1 255.255.255.0
interface Vlan22
ip address 1.1.6.1 255.255.255.0
interface Vlan23
ip address 1.1.5.1 255.255.255.0
nterface GigabitEthernet7
description LAN LINK to Switch
switchport trunk native vlan 77
switchport trunk allowed vlan 1,2,20-24,1001-1005
switchport mode trunk
Switch Config:
vlan 20
discription management vlan
vlan 21
vlan 22
vlan 23
vlan 77
interface Vlan20
description MGMT VLAN
ip address 1.1.8.100 255.255.255.0
interface range Gi 0/1
description UPLink to Router
switchport trunk allowed vlan 20,21,22,23,24,1,1002,1005
Deepak Kumar
There will not things:
1. Check your switch configuration, If there is a command "IP routing" then you must remove the command (no ip routing) first.
2. "IP default-gateway 1.1.8.1" must be configured on the switch means VLAN 20 Gateway IP.
Last thing: There is interface configuration is also showing a VLAN mismatch.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
8 Replies 8
Jon Marshall
Can you post a "sh ip int br" from both devices.
Jon
Deepak Kumar
Deepak Kumar
Deepak Kumar,
hi,
i am showing sample config.in my real device i use /27 for all VLAN.for example. I use 10.1.8.0/27 for vlan200,10.1.8.64/27 for vlan201,10.1.8.94/27 for vlan 202 (mgmt network).If i use vlan 200 as mgmt network and use 10.1.8.1 as gateway,i can reachable to switch and swich can ping anywhere.but if i use other vlan as mgmt net,switch cannot reach anywhere.
Best to show real configuration in future.
If you use a different vlan for management are you also changing the default gateway to an IP from the new subnet ?
Jon
Please post complete configuration and hopping that you missed a command on the switch:
ip default-gateway 1.1.8.1
Deepak Kumar,
absuizo14
This maybe a stupid question but why do you have a trunk interface and vlans on your router? Switch port modules?
A trunk interface is used to carry multiple VLAN traffic on a single interface. In your case, you used trunk port because you want to carry VLAN 2, 20, 21, 22 etc on a single interface.
Deepak Kumar,
There was a request for the output of show ip int brief from both devices. I believe that this output would be helpful. In addition would the original poster give us the output of show cdp neighbor from both devices and the output of show interface status from the switch?
Rick
Rick
