Cisco switch 2960 connecting TV box with cat5
LUKASZ KITA
Having problem connecting TV box (Oasis)  to a switch 2960
After connecting to any port, the port goes up and after couple of seconds goes down
I have changed duplex, speed. Still does not work
Are those TV boxes use different protocols?
I have also checked on my ASA 5505 and does not work
But after connecting same cable to the linksys WiFi router that runs thru ASA, everything works.
Any idea?
Luke
Hello
try defaulting the interface
Default int x/x
int x/x
switchport host
no shut
end
Kind Regards
Paul
5 Replies 5
Leo Laohoo
Goes up for a few seconds?  Post the complete output to the command "sh interface status err".
I would also like to see the complete output to the command "sh interface <PORT>".
mohammed01701
Hi!
Change the speed MAYBE the TV box accepts only one speed, i mean it is not supported auto speed, If it is giginterface change to 100, if it is fastethernet configure to speed fast 100 mbps:
interface gig x
 speed 100
inteface fa x
 speed 100
/Mohammed
what is the exact model ? Is that an OASIS Mediaplater ?
Cat5 is very old. Try at least Cat5e or 6...
Also, try and configure 'spanning-tree portfast' on the 2960 port...
Hello
Default int x/x
int x/x
switchport host
no shut
end
Kind Regards
Paul
Thanks for the help
it worked
