cisco switch 2960-X series, port restriction to 30 wlan users
carlosnolasco1
Community
I have a switch catalyst 2960-X series, to which I connect two access points that support Up to 100 users each.
I have connection problems since the access point loses connection momentarily
In the documentation of the switch each port has to be configured, either Desktop, cisco switch, cisco router, access point. Etc
In the help page,  setting the port as an access point it says the following:
"Apply this profile to the ports to be connected to wireless access points. The access point can provide access to the network to a maximum of 30 mobile (wireless) users."
There is way to remove that restriction in the port, since my equipment support more.
Thank you.
Reza Sharifi
What document is that?
Can you provide a link to it?
its ok if i send you a document with the image.
Dont now on line were is that.
That is fine. I saw it in the attachment.  I don't think that comment is correct, as the number of mobile devices support by an AP is based on the AP itself and not the switch port.  The switch port does not impose how many devices can connect to an AP.
