Cisco switch 4506 E
moh_efrangi
Frequent Visitor
Frequent Visitor
Hello ;
my customer having a PC with NIC card 10 copper and he need to connect directly to the Core switch 4506 E , the problem here the switch having a
module of WS-X4748-RJ45-E and WS-X4712-SFP+E so is there any solution to solve this issue with keeping the 10 Gig speed like a module or a
transceiver  or any solution without changing the NIC card to fiber 10 Gig .
thanks
Joseph W. Doherty
What sup model are you using?
Sup6 cards have X2 which supports copper modules, the sup7 or sup8 have SPF+ which I believe do not.
chrihussey
They are pretty pricey and not sure what the cost comparison is versus buying a new NIC, but you could look at using a media converter.
https://www.perle.com/products/10gbase-t-standalone-media-converters.shtml
(This is just one I found, and you'd still have to use two SFP+ in addition to the cost of the converter.)
