cisco switch config info/ certificate self signed 01 and the hex after / backing up configs
surbris.com
ok so any one out there knows that backing up your configs for your switchs sucks.
there is a free program out there called r config
i love it but i have hit an issue.
when i do a back of of switch ## of 130 switchs i get a fail to save the show run   to a file (i'm using r config to ssh and use security info(user/password) to ssh download to my r config data base
when it failes  its allways at this line
certificate self-signed 01
crypto pki certificate chain TP-self-signed-XXXXXXXX
  3082032E 31840216 A0030201 02024101 300D0609 2A864886 F70D0101 05050030
  30312E30 2C060355 04031325 494A531D 53656C66 2D536967 6E65642D 43657274
  ECA15D69 11970A66 252D34DC 760294A6 D1EA2329 F76EB905 6A5153C9 24F2958F
  D19BFB22 9F89EE23 02D22D9D 2186B1A1 5AD4
 each of the ##/130 switchs i have found to fail  fail at the same spot,     i have asked a friend way smarter then me and he thinks its a MTU 1500 thing where the hex is maxing out the mtu.
i would love to know what the hex is and why 70% of my switches pass the download but the 30% with the long hex fail
what is the hex,  is the self signed 01 old and needing update  ???? is this a version of the ciso swiches os needing updating???
what im i missing.
what do i look up   need names to do google searches ..... o   mighty cisco good in your chairs please help
pieterh
the word says: certificate self-signed 01
so it is the first self-signed certificate present in the configuration.
as such it is just an output-string in the show running-configuration not more not less.
yes it can be that the tool i used (r config) has a buffer that is too small for this output, but that has no relationship with MTU size. more likely is the switches that fail the backup have certificates with a longer key-size (1024 or even 2048 bits key ) then the switches that succeed (they may have certificate with 512 bits key?) and a buffer-overflow occurs.
-> guess you need to look into the properties of this tool to see if you can increase the input buffer size.
