Cisco Switch CPU Threshold
Femi_jkk
Visitor
Hi Team,
Please help me to check the attached CPU threshold output which i got from my switch when i used "show processes  CPU  history" command from the SSH.
I want to know what could have caused this and what needed to be done to rectify it.
I will appreciate swift contributions from experts who has had same issue on their switch.
Mark Malone
theres nothing wrong there cpu is very low , check you show proc cpu sorted to see if it high currently but loks to be only 20%
CPU also needs to be captured in real time so after the fact wont show you much anyway apart from it ran high
This is what you would need to worry about , im dealing with this on a switch now due to a CPUHOG with ISE , this is considered high service effecting cpu
1111111111111111111111111111111111111111111111111111111111
0000000000000000000000000000000000000000000000000000000000
100 ##########################################################
90 ##########################################################
80 ##########################################################
70 ##########################################################
60 ##########################################################
50 ##########################################################
40 ##########################################################
30 ##########################################################
20 ##########################################################
10 ##########################################################
0....5....1....1....2....2....3....3....4....4....5....5....
0 5 0 5 0 5 0 5 0 5
CPU% per minute (last 60 minutes)
Mark Malone
0 5 0 5 0 5 0 5 0 5
Thanks for your quick response. Just worried about the flapping as shown in the attachment, or don't you think it calls for concerns!!!?
sorry what do you mean flapping the attachment only shows CPU history , is there more that did not upload ? also was this switch rebooted ? just wondering as the CPU history has like a flatline
also if this only happened please post both below commands , if the switch has been rebooted the show logs will not provide anything though
show proc cpu sorted -- this will show current usage
show loggs - may show anything irregular that may have happened
