Cisco switch firepower 2010
I successfully logged to my cisco switch firepower devices. however I am trying to access the GUI connection I am receiving connection timeout. example https://192.168.x.x  I received the warning to add the exception then the connection timeout?
I went through he configure terminal steps  and # enable http process
Also can I use the CLI command on my cisco switch to ASDM i
like once ssh to the switch, install  ASDM to access via https or gui  interface?
If so which command will I use.
The first question is what kind of device you really have, there is no Cisco switch Firepower 2010 ...
There is a Firepower 2110, but it is not a switch, it's a firewall. It could run an ASA image and with that, be configured with ASDM, but then your command doesn't match.
Please post a "show version" to make sure what you have.
 If you enable http with  the command enable http process, then you need to access using http://192.168.x.x
If you want to use https://192.168.x.x then you need to enable https with ip http secure-server
Yes, You are correct if's Firepower 2110. I want to create a tunnel between the Firepower 2110 and the Cisco 5520.
I was able to successfully configure the firepower 2110 and now need to create a tunnel between the two devices.
Thank you
