12-08-2011 10:50 AM - edited 03-07-2019 03:48 AM
I am having an odd problem with SNMP, I have a Pair of Nexus 5548 UP's and the SNMP is setup very simply v2 with a RO communitee string, I had both devices setup on my SNMP NMS and after a few days one of the devices stopped responding to SNMP, I have verified and re-entered the settings and still it does not work. I am using a SNMP testing tool as well, works flawless on one but fails on the other. I have full connectivity to both devices as well.
Any ideas?
Solved! Go to Solution.
01-04-2012 03:56 PM
Hi Jerry
I had similar issue as Jason.
the version on nexus is 5.0(3)N2(1)
It looks to me that snmp had been hanged for a while
dcassw202# sh processes cpu sort
PID Runtime(ms) Invoked uSecs 1Sec Process
4565 1308 3838622539 0 46.5% snmpd
4681 184 90 2045 5.0% netstack
4476 1054 14064363 0 1.0% pfma
Your any suggestion will be very appreciated.
01-04-2012 07:00 PM
Hi George,
I believe you are hitting the following bug
You can upgrade to 5.0(3)N2(2b).
jerry
12-09-2011 06:48 AM
simple question can the device that is failing ping the snmp collector?? Also what is the SNMP timeout period you have configured on the collector?
12-09-2011 08:52 AM
Hello Andrew,
Thanks for the respones, the failing Nexus 5548 can indeed ping the SNMP collector, and I am using Solarwinds which by default the timeout period is 2500ms
12-09-2011 09:03 AM
Also, I am running a Debug SNMP all command on both devices, the failing device has this:
snmpd: pm_snmp_process_ethernet_counters_n_update_cache: error: statcl_parse_all_intf_mod_msg failed
I wonder how to fix?
12-09-2011 07:07 PM
What version of NX-OS are you running on these 5548s???
jerry
01-04-2012 03:56 PM
Hi Jerry
01-04-2012 07:00 PM
Hi George,
jerry
01-10-2012 10:38 AM
I succesfully upgraded to the latest firmware and my issues have been resolved.
thanks for your comments and help
01-04-2012 07:30 PM
thanks Jerry for quick response.
"Workaround:
Unload the BRIDGE-MIB from the switch by using snmp server commands. If the switch is reloaded
you will have to redo step 1 as this command is not persistent. For detailed information on the
workaround please contact Cisco TAC. "
Regarding to temporary workaround, do I need to disable snmp and enable snmp back on the switch to solve this issue?
01-04-2012 07:41 PM
Hi George,
Disable SNMP will not fix this problem, you have to unload the BRIDGE-MIB to free up the memory. However, per the bug's release note, this information needs to come from TAC only.
jerry
01-04-2012 09:55 PM
Hi Jerry,
the workaround solved my problem. Now snmp is back working now.
Thanks for help
01-05-2012 07:00 AM
Hi George,
Did you unload the BRIDGE-MIB? If yes, just FYI, this is setting will not persist if the switch is reloaded. You have to do this command everytime after reload.
jerry
01-04-2012 03:45 PM
Hi Jason,
I had similar issues on nexus about snmp.
I wonder whether you have solutions on it.
thanks
01-04-2012 11:16 PM
Hi George,
I am also facing the same issue with SNMP monitoring for Nexus 5596UP. I am using Solarwinds NPM 10.1.3 for monitoring and it was monitoring fine until I upgraded to v10.2. Solarwinds TAC suspected an issue with Nexus.
Can you let me know the workaround which solved the issue with SNMP monitoring?
TIA
AJ
01-05-2012 02:56 PM
the wo:
1. Unload the BRIDGE-MIB from the switch by using the command "no snmp-server load-mib dot1dbridgesnmp"
2. Verify it is not loaded by using the command "show snmp internal all_loaded_mibs | include bridge"
3. If the switch is reloaded you will have to redo step 1 as this command is not persistent.
Please remember that this is temporary solution. If the switches being reloaded, you need implementing the commands again
