01-22-2015 08:31 PM - edited 03-07-2019 10:21 PM
I'm looking for a 24-port SFP switch. Each of the two switches in the subject meets that requirement. If I went with the ME switch over the 3750 (at about half the cost).
ME-3600 also have L3 feature. For now i still not sure what is different between these. Please give some advises.
Mano
01-23-2015 09:45 AM
Hello PutmanoAIT,
What other features are you looking in for a switch? I can help you find the best solution that will fit your requirements. Kindly send me an email (alyreyes@cisco.com) so I can assist you further.
Hope to hear from you soon.
Alyza
01-28-2015 08:50 AM
Dear Alyza,
Thanks for your support. what i looking for is L3 that have 24 SFP ports.
I looking for catalyst 3850 with 24 SFP port and ME Switch 24 SFP port. Price very different.
Feature that i want is SVI HRSP OSPF and some layer 3 for enterprise support.
Any advise for that case?
01-23-2015 02:37 PM
The Cisco® Catalyst® 3750-X and 3560-X Series Switches are an enterprise-class lines of stackable and standalone switches, respectively. These switches provide high availability, scalability, security, energy efficiency, and ease of operation with innovative features such as Cisco StackPower (available only on the Catalyst 3750‑X), IEEE 802.3at Power over Ethernet Plus (PoE+) configurations, optional network modules, redundant power supplies, and Media Access Control Security (MACsec) features. The Cisco Catalyst 3750-X Series with StackWise® Plus technology provides scalability, ease of management and investment protection for the evolving business needs. The Cisco Catalyst 3750-X and 3560-X enhance productivity by enabling applications such as IP telephony, wireless, and video for borderless network experience.
Cisco Catalyst 3750-X and 3560-X Series primary features:
● 24 and 48 10/100/1000 PoE+, non-PoE models, and 12 and 24 GE SFP port models
● 24 and 48 10/100/1000 UPOE-capable models with Energy Efficient Ethernet (EEE) support
● Four optional uplink network modules with GE or 10GE ports
● Industry first PoE+ with 30W power on all ports in 1 rack unit (RU) form factor
● Dual redundant, modular power supplies and fans
● Media Access Control Security (MACsec) hardware-based encryption
● Flexible NetFlow and switch-to-switch hardware encryption with the Service Module uplink
● Open Shortest Path First (OSPF) for routed access in IP Base image
● IPv4 and IPv6 routing, Multicast routing, advanced quality of service (QoS), and security features in hardware
● Enhanced limited lifetime warranty (LLW) with next business day (NBD) advance hardware replacement and 90 day access to Cisco Technical Assistance Center (TAC) support
● Enhanced Cisco EnergyWise for operational cost optimization by measuring actual power consumption of the PoE devices, reporting, and reducing energy consumption across the network
● USB Type-A and Type-B ports for storage and console respectively and an out-of-band Ethernet management port
In addition to the above features, the Cisco Catalyst 3750-X switches also offer:
● Cisco StackPower™ technology: An innovative feature and industry first for sharing power among stack members
● Cisco StackWise Plus technology for ease of use and resiliency with 64 Gbps of throughput
● Investment protection with backward compatibility with all other models of Cisco Catalyst 3750 Series Switches
Get the capabilities you need to boost transport speeds to 10 Gbps in the access layer for business and mobile applications with the Cisco® ME 3600X Series Ethernet Access Switches. The first Cisco switch series built specifically for the convergence of wireless and wireline services and an evolution of the Cisco Carrier Ethernet portfolio, the Cisco ME 3600X Series extends the portfolio’s transport speed and allows service providers to initiate Multiprotocol Label Switching (MPLS)-based VPN services from within the access layer. Designed around key Carrier Ethernet features that simplify network operation, the Cisco ME 3600X Series supports premium services with enhanced service-level agreement (SLA) capabilities. An optional “pay-as-you-grow” feature and service activation model add up to a flexible, cost-effective service provider solution.
The Cisco ME 3600X Series Ethernet Access Switches (Figure 1) are 1-rack-unit (1RU), fixed-form-factor platforms available in copper and fiber hardware-optimized configurations:
● Cisco ME 3600X-24TS-M (copper) with 24 10/100/1000 ports and two 10 Gigabit Ethernet SFP+ ports
● Cisco ME 3600X-24FS-M (fiber) with 24 Gigabit Ethernet SFP ports and two 10 Gigabit Ethernet SFP+ ports
I hope this helps!!!!!
Please rate if resolved your question.
01-27-2015 08:46 PM
Hi Lenperez
We recently upgrade our access switch from 3750 to 3750X.
but Cisco website recommend 3850.
Our switch is mainly for user connecting their PCs to the network so should we go 3850 or
stay with 3750-X or 3760x .
Please advise
Peter
01-28-2015 08:54 AM
Cisco ME Switch also support L3 feature like OSPF SVI HSRP ACL ? all these are what i need.
I know ME Switch is use for SP but if it can meet my requirement and price is better that Cisco Catalyst i will prefer it.
01-23-2015 05:16 PM
Not enough info. Exactly what are you trying to achieve?
3750X maybe a Layer 3 switch but 3750X supports only VRF-lite and cannot support MPLS/VRF.
01-28-2015 08:56 AM
My requirement that i need are some L3 feature like OSPF HSRP ACL SVI. If ME Switch can support these feature i will prefer it because price almost half different.
Thanks for you advice
01-28-2015 02:24 PM
And how many SFP ports do you need? I agree with Joseph, the 3750X can be stacked. If you need more than 24-port SFP then 3750X would be sufficient. If you need less than 24-ports SFP then either an ME-3800 or a 4500X (with modular SFP ports) can be considered.
NOTE: Due to some IOS-XE issues with 3850, I will not be recommending this model.
01-28-2015 06:17 AM
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
The 3750-X series is stackable (both data and power), the ME switches are not.
The 3750-X series is oriented to typical LAN L3 switch usage, the ME switches are oriented to working with Metro Ethernet, also as a service provider.
Lenperez's post has many more details.
Which switch is best for your usage, as Leo asks, depends on what you want to achieve or your networking requirements.
01-28-2015 02:20 PM
Hi Joseph,
what about the 3850 series which Cisco is pushing on their web site.
Our network requirements are for connectivity to the network from users' PC.
so what features should we look for ?
Peter
01-28-2015 05:29 PM
Disclaimer
Posting
The 3850 (and 3650) series, are really the successors for the 3750-X series, although, neither might have a 24-SFP model.
As to what features to look for, those would be whatever you believe you need. For basic L2 and L3 features, either will likely suffice.
01-28-2015 05:55 PM
3850-12S & 3850-24S has been available for the last few months.
Whether or not IOS-XE is stable or not is a debate.
