Cisco switch Port-channel & F5 Trunks setup failover
Yuvi1983
Hi Experts Community,
Actually, in my production environment I like to have full 100% failover working for the F5 load Balancers those are connected to Cisco VPC pair switches, I am having the topology shown below. In this topology the green links are already connected & configured & working for traffic, recently I found there is NO cross connection between the F5s & Cisco switches. This caused issues when one of the Cisco switches failed, VPC functionality working as expected between the Cisco switches.
Now I am adding the cross connections between the F5s & Cisco switches (show in red in topology)
My new config on the Cisco switches
SW01, Port 1/34-35
SW02, Port 1/34-35
My New config on F5 LB
Adding the port 1.4 & 2.1 in the Existing Production Trunk1 interface on F5 (Interface 1.4 & 2.1 free on F5)
Scenerio1: If the SW02 (Current VPC primary) fails, the VPC failover will happen & SW01 becomes the VPC operational primary.
In this situation F5-2 will Forword the traffic via SW01?
Scenerio2: If the SW02 came up & Operational primary
In this situation F5-2 will start traffic forwarding via SW02 again?
Kindly review, I am doing anything wrong here to achieve the failover for the F5 traffic via switches using the new cross links? (shown in RED in topology)
I request please review above topology & failover scenarios for traffic from F5 to Switches during switch failover.
Note: I thought of configuring the VPC for F5, unfortunately required to break the existing PO25 & Thinking that will cause traffic issues during the VPC config for these interfaces those are already carrying lots of production traffic.
Thank you so much ..Yuvi
@Yuvi1983  I asked the version because interface bound started in version 10.1
https://my.f5.com/manage/s/article/K13142
You are not doind enything wrong and the answer for your questions is Yes.
@Yuvi1983
Which is the BigIP model and version?
The BigIP is 5050 & Software version 13.1.3.6
Thank you so much for all support
