Cisco Switch Unable to Access Management Interface
natchannel
I have a Cisco Cataylst Switch in L2 mode, connected to a WatchGuard firewall/router using the "router on a stick" topology. Currently all network traffic for all VLANs is traversing across the switch without issue. However I am unable to reach the switch itself outside of the management VLAN 2. The switch and the router can ping each other. I know routing to VLAN 2 works as other devices on that VLAN route just fine. When trying to ping from the Cisco switch to any IP outside of its VLAN, it fails and the router doesn't even see any traffic attempting to leave. Below is a snippet from the config.
interface Vlan2
 description Management
 ip address 10.100.0.2 255.255.255.0
 ip access-group 111 in
 ip access-group 111 out
ip default-gateway 10.100.0.2
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip ssh version 2
ip name-server 10.0.0.20 10.0.0.21 10.100.0.1
ip access-list extended 111
 10 permit ip any any
! this is the uplink port to the router
interface GigabitEthernet1/0/1
 switchport trunk allowed vlan 1,2,10,30,40
 switchport mode trunk
! this is an downlink port to a wireless AP
interface GigabitEthernet1/0/2
 switchport access vlan 2
 switchport trunk native vlan 2
 switchport trunk allowed vlan 2,10,30,40
 spanning-tree portfast trunk
! this is a general wired access port for PCs and VoIP phones
interface GigabitEthernet1/0/29
 network-policy 1
 switchport access vlan 10
 switchport mode access
Reza Sharifi
The default-gateway IP should be the next hop IP address (firewall) and not the IP address of the switch
interface Vlan2
Reza Sharifi
interface Vlan2
Wow, brain fart there. Thanks for spotting it for me, fixed the IP and everything is working!
No problem. It happens to all of us.
Good luck!
