Cisco Switch
abbas.ali
Level 3
Level 3
I was checking the specs of Cisco 3750G-48 port switch stated that it does 38.7 mpps on a 32GB Switch Fabric.
Am I right to conclude the oversubscription 6:1?
Sandeep Choudhary
Hi Abbas,
specifications for the Cisco Catalyst 3750 Series.
• 32-Gbps switching fabric
• Stack-forwarding rate of 38.7 mpps for 64-byte packets
About the oversubscription, please follow this post to understand in detail.
https://supportforums.cisco.com/thread/147740
https://supportforums.cisco.com/thread/146858
Hope it helps.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
No, it isn't quite that bad.  The 3750G-48 has 52 (duplex) gig ports (discounting StackWise prots), so its 104:32 or 3.25:1.
The forgoing is for bandwidth, for PPS, the same 52 gig ports could demand up to (about) 75.3 Mpps, so 75.3:38.7 or 1.9:1.  (NB: Effective PPS will usually improve with larger packets.)
