Cisco Switch
Please suggest a model which can meet the requirement.
Core switch to 19" 24 port Layer2/3/4 managed switch with 24*1gig sfp port 184 switching capacity 136Mpps forwarding rate.
Thank you
Q1. A switch with 20 x SFP ports and 4 dual-personality ports in a 1 RU size.
A1: Cisco doesn't have this model.
Q2: A 48-dual-personality-port in a 1 RU size.
Q2: Cisco doesn't have this model.
7 Replies 7
Leo Laohoo
WS-C3850-24XS
(WS C3850 24XS)Will it support 1000Base T SFP transceiver P-O-E adapter.        Please suggest a model which can meet the requirement for Edge switch 19" layer2/3 Managed 48 port 10/100Base T ports ,Dual purpose gigabits port (10/100/1000 or sfp) including 100Base SX sfp transceiver ,P-O-E adapter   Thank you
1000BaseT SFP with PoE???
I don't think so. No one has invented a 1000BaseT SFP with PoE.
I mean GLC-T with POE support
As far as I'm aware, no SFP manufacturer has invented a GLC-T module that supports PoE.
The only way around this is to get a GLC-T module and connect a Power Injector to power up the end device.
If you're going to get a 3850-24X, how many ports will require PoE?
OK Thank you for your advice .
(1)CORE SWITCH TO CISCO 19'' 24 PORT LAYER 2/3/4 MANAGED SWITCH WITH 20 SFP GIG ports, 4 DUAL PERSONALITY SFP OR 10/100/1000/PORTS EXPANSION  MODULE,184 GBPS SWITCHING CAPABILITY , 136 Mpps forwarding rate,1000 BASE SX SFP.
(2)Edge switch 19" layer 2/3 Managed 48 port10/100 BASE T ports ,DUAL PERSONALITY GIG PORT (10/100/1000 OR SFP)
Thank you .
