Cisco Switches 3850 Stack of Two
Hello all
I want to create a stack of two switches 3850-48 ports. I am not sure how many cables should I need for this process :
Stack Cable
Power Cable
Reza Sharifi
For stacking, you only need to stack cables.
If you want to do power stacking, you need one power stacking cable.
data stacking 2
power stacking 1
Thanks for the reply but in this way, if I have only one stack cable
I can't do it
Yes, you can use 1 stacking cable but you will not get the full stacking bandwidth and you will not have any redundancy in case one cable gets disconnected or go bad.
