Cisco switches & routers preventing maintenance
hadelmahmoud
Dear All;
first I would like to thank this forum because really it is very helpful.
I need preventative maintenance tool for Cisco switches & routers such that how many times happened failure in hardware
your fast reply is highly appreciated.
hadelmahmoud
could anyone please help me. how can I do preventive maintenance to cisco 3560-6500?
Best Regards;
glen.grant
There is no way to predict hardware failure. The best you can do is to use a good tool like the Orion program and or ciscoworks if you have the money . Make sure you have applicable snmp traps turned on for the hardware and get things like power supplies fixed as they break. Things like a supervisor cards don't break that often . The highest failure items seems to be power supplies particularly on the 4500 series for some reason.
Dear glen.grant ;
thank you for your fast & helpful reply and kindly be informed that I have already cisco works so could you please advice me how can I do that through cisco works?
Best Regards;
Hany Adel
