Cisco trunk port to VOIP phone
Andy White
Level 3
Level 3
We we have an office which is using a hosted IP provider but they just have 15 x non Cisco desk VOIP phones and have their PC's plugged into them all on VLAN 1.
I've created 2 VLANs there, 1 for Data and the other for Voice, would I just need to make the switch ports a trunk and set the phones to the voice vlan?
Any example port configs woud lbe great.  They don't have QoS either which I may add.
5 Replies 5
Karthick Murugan
Hi Andy,
Please find the configuration below. It should work fine without any issues.
vlan 301
name Data
vlan 309
name VoIP
lldp run
interface FastEthernet0/9
description PC & IP Phone
switchport trunk native vlan 301
switchport trunk allowed vlan 301,309
switchport mode trunk
spanning-tree portfast trunk
spanning-tree bpduguard enable
Thanks & regards,
Karthick Murugan
CCIE#39285(R&S)
Thanks & Regards, Karthick Murugan CCIE#39285
That is how I did it, the only thing I have missing is "lldp run" what is that?
Hi Andy,
I am very glad that you got the configuration right.
LLDP is a replacement for CDP.
CDP is to detect the neighbor device(Cisco) and LLDP can be used for Avaya.
Karthick Murugan
Just one thing I noticed I didn't use the "switchport trunk native vlan x" would this be for anything untagged?
"switchport trunk native lan x" is the replacement for "switchport access vlan x" in both the cases the VLAN will not be tagged.
Karthick Murugan
